Pulling Advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 03RescueDiesel, this thread has received 9 replies and been viewed 746 times.
post #1 of 10 (permalink) Old 07-22-2007, 02:02 PM Thread Starter
9/11/01 343
03RescueDiesel's Avatar
Send a message via AIM to 03RescueDiesel
Pulling Advice
Hey guys got a couple questions about sled pulling and first time questions.
1. Will my stock hitch be ok ?
2. I have 37x12.50 PJ's are these tires ok for this and can handle it?
3. How should I prepare for my first pull?
4. 4Hi or 4low start in 2 gear or 1st.
5. I have an all spring lift kit is this ok ?
03 F250 PSD CC LB Fx4 Wouldnt you like to know whats going
TDG Singles club #228
TDG RIDIN' DIRTY #43
TDG Member Feb 2006
Qauntico Fire Dept, Dale City Volunteer Fire Dept
9/11/01 All Gave Some Some Gave All 343.
03RescueDiesel is offline
post #2 of 10 (permalink) Old 07-22-2007, 09:54 PM
i woul pull in 4L 2nd tow haul mode and take off easy, get the sled moving then start pouring the fuel to it. just dont let it start hopping bad things will happen. if 2nd is to low shift to drive and tow haul mode.
Scott
SmokingIDI_7.3L is offline
post #3 of 10 (permalink) Old 07-22-2007, 09:57 PM
oh ya air down your tires, i put mine a bout 10psi and if you can block the rear supension.
post #4 of 10 (permalink) Old 07-23-2007, 10:26 AM Thread Starter
9/11/01 343
block the rear ?
TDG Member Feb 2006
post #5 of 10 (permalink) Old 07-24-2007, 05:38 AM
Wondering the same thing...what is blocking the rear?
cdiesel is offline
post #6 of 10 (permalink) Old 07-24-2007, 02:34 PM
It keeps your rear suspension from working, basically disabling your springs. This transfers more power to the ground, I'm not sure exactly how much energy is lost in the suspension???
mckey73 is offline
post #7 of 10 (permalink) Old 07-24-2007, 06:31 PM
It lets the frame sit down on the blocks and makes it solid so you don't bounce (bouncing = breaking). Same with ladder bars, they help prevent axle wrap.
Some places have rules that require a certain amount of suspension travel (usually 1 or 2 inches). Its pretty much pointless, because once the frame bottoms it should stay there and won't move anyway
-Michael
imported_Dieselfever is offline
post #8 of 10 (permalink) Old 07-24-2007, 10:29 PM
I understand the Ladder bars, but how do you block the rear temporarily?
cdiesel is offline
post #9 of 10 (permalink) Old 07-25-2007, 12:23 AM
pontiacross's Avatar
for my truck I built a piece that bolt to the factory bump stop so when it squats a little it bottoms out the axil faster and cant go down any more
I 'll try and get a picture.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #10 of 10 (permalink) Old 07-25-2007, 12:30 AM
here ya go
with out stopsAttachment 12391
with stopsAttachment 12392
ID:	11314   Click image for larger version
Ross
Tow Rig
