Bouncing Problems... badddd - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Teelo, this thread has received 14 replies and been viewed 1496 times.
post #1 of 15 (permalink) Old 07-26-2007, 07:13 AM Thread Starter
We just got done pulling at the southern kentucky fair, and our d max was bouncing like hell on the track... were running new suspension blocks and new traction bars and i *think* the traction bars (home made) might be the cause, not sure though.
Any ideas on how to reduce all the bouncing?
Teelo is offline
post #2 of 15 (permalink) Old 07-26-2007, 07:29 AM
AKA slowdog racing
Send a message via Yahoo to maddogg1019
did you come outa the hole real hard
-Curtis-
2006 chevy 2500 LBZ ec sb AKA Blue Blur :chevy-EFI live from mcrat and a few slowdog racing tunes, AFE stage 2 with PG 7, MBRP 5" turbo back,Bilstein shocks, Autometer cobalt pyro and boost, BD fullbore manifold, SD manifold, 2" block in the rear, caltracs traction bars, and 33 x 12.5 r 16.5 sport kings. 2 10" memphis subs, 1050 max watt lightning audio amp, alpine head unit.
[email protected] mph with whats above.thanks pat and kat.
coming soon - suncoast V trans., slowdog duel pumps
"Its a matter of horsepower for eight seconds or miles an hour that's the way i am and it's a fact i cant ignore yeah big four-legged, fuel-injected runnin' wild or radar-detected a man can always stand a little bit more horsepower."-Horsepower-Chris LeDoux
Me kickin azz
My truck and other things
Myspace
maddogg1019 is offline
post #3 of 15 (permalink) Old 07-26-2007, 11:08 PM Thread Starter
yeah i did a boosted launch, but it only started bouncin when it got into 3rd gear
Teelo is offline
post #4 of 15 (permalink) Old 07-26-2007, 11:55 PM
pontiacross's Avatar
I'm glad I'm not the only one with that problem
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #5 of 15 (permalink) Old 07-27-2007, 10:57 PM
torshion bars maybe?
Do you lower your torshion bars, i have never seen a chevy with the torshion bars lowerd blocked rear suspension traction bars bounce
99Binder is offline
post #6 of 15 (permalink) Old 07-28-2007, 12:37 AM Thread Starter
no ours are all the way raised
were thinking about replacing the shock with a pipe in the front
Teelo is offline
post #7 of 15 (permalink) Old 07-28-2007, 04:22 PM
Destroked
diesel dan's Avatar
Pump your rear tires up to around 65-70psi and it will stop.
diesel dan is offline
post #8 of 15 (permalink) Old 07-29-2007, 12:32 AM
BogginF350's Avatar
Agreed... this will help. If wore comes to worse have some pulling springs built.
www.alcanspring.com
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #9 of 15 (permalink) Old 07-29-2007, 11:05 PM
Tire pressrues are key, also watch the sled and track usually seems all the guys go to one side run the other side.
#23 Singles Club
thejdman04 is offline
post #10 of 15 (permalink) Old 08-01-2007, 05:11 AM Thread Starter
do you all thinking blocking the front suspension would help?
Teelo is offline
