Sled pull ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by payne86, this thread has received 5 replies and been viewed 1011 times.
post #1 of 6 (permalink) Old 08-15-2007, 10:49 PM Thread Starter
payne86's Avatar
Sled pull ?
I was just wondering why at the end of each sled pull as soon as they stop, they rev it up alittle?? only thing i can think of is to help burn all the extra fuel left after a wot run. ?? just something i was thinking about.
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
post #2 of 6 (permalink) Old 08-16-2007, 01:42 AM
Ya I was kinda wondering that too but I always thought it was to slow the turbo down a little slower so it dont bark real bad? But iam not sure
Big Gray dodge is offline
post #3 of 6 (permalink) Old 08-16-2007, 02:11 AM
diesel_ram_man's Avatar
Images: 6
They do it to help bring the boost down slowly, than just letting off the throttle and barking like crazy. Especially with how big of turbos most sled pullers run.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #4 of 6 (permalink) Old 08-16-2007, 04:09 AM
Good on gas, hell on dzl
DZL HOG's Avatar
To keep it from cutting off. Goin from full boost to no boost immediately, will cut the air off to the engine and it will stall. Atleast thats what it seems like my truck does. Ive had it happen to me a couple times, both times I was pulling. One was sled pull, other was a tree in the backyard. If I would hold it down for a short while, then let up real quick it would bark then cut off. Hold her down, let up quick, then tap it alil, it wont cut off. That was just with an exhaust system, no tuner then.
2006 F250 Super Duty Harley Edition #00604
Black with blue flames Crew Cab, long bed.
MBRP 4" Duals, AEM intake, Accufab elbow, SCT tuned by DJ(Looney)and Spartan, DJs Fuel + Intensifier, Dieselsite coolant filter, Commander monitor for gauges, PML front diff cover, cheap locker in front, Icon leveling kit, Icon Dual steering stabs, OneUpOffroad front link arms, OUO 5" traction blocks, Bed Rug, Pace Edwards Bedlocker.
DZL HOG is offline
post #5 of 6 (permalink) Old 02-04-2008, 11:28 PM
if the sled brings you down it will loud the mtor too much and the turbo cant spool that way either so if u rev it up at the quickly enough you can keep it from stalling.
jd_craft is offline
post #6 of 6 (permalink) Old 02-06-2008, 02:56 AM
On my truck, and I guess this applies to most Duramaxes, The converter will be locked in 4th gear at the end of the pull. If you let off the pedal and don't go to neutral the motor will stall. Not good for the turbo bearings as the oil pressure stops feeding the turbo and what oil is on the bearings, cokes up pretty fast with all the heat present. JMO
02freighttrain is offline
