September truck pull in Florida - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MoPower05, this thread has received 2 replies and been viewed 516 times.
post #1 of 3 (permalink) Old 08-20-2007, 10:57 PM Thread Starter
When: September 15th, 2007 starting at 5 pm.
Where: Charlotte County Fair Grounds 2333 El Jobean Rd.
Directions: I-75 to exit 179 then south on Toledo Blade across u.s. 41 then right on El Jobean Rd also(s.r. 776) until you see the fair grounds.
Pulls start @ 5:00 p.m., weigh-in at 3:00. This will be a regular all pull event.
All diesels will pull in one class regardless of mods. We will seperate the trucks on paper after the event to see who won the stock turbo class.
Try and make it. It's a long track and you need some fairly good speed .
Bring your more agressive tires. 8,000 lb. Hanging weight ok.
Dont this weekends truck pull August 25th at Wauchula.
2005 dodge 3500, qc, drw, 4x4 flat bed, cummins edge hot w/A2, 5" mbrp turbo back, stage II afe intake, tracton bars, 12000 lbs hitch, BD lift pump, suncoast converter.
http://profile.myspace.com/index.cfm...ndid=352446226
MoPower05 is offline
post #2 of 3 (permalink) Old 08-24-2007, 11:47 PM Thread Starter
More info and pictures will be coming soon just check out
www.southfloridatruckpulls.com
post #3 of 3 (permalink) Old 09-05-2007, 11:15 PM Thread Starter
September 15th is almost here you should know by now if your going to be there. This is a good track to try for the first time. There isnt much traction so those of you that are afraid of hurting your daily driver this track is for you. Whos coming?
:sofa
