Need help on tire combo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MoPower05, this thread has received 9 replies and been viewed 1156 times.
post #1 of 10 (permalink) Old 09-21-2007, 12:32 PM Thread Starter
I have been tring different tire set ups for pulling and wondered what others have found to work best with a dual wheeled truck? More aggesive in front a/ts in the rear - non dually wheel in front maybe a 10" wide? Because there are two wheels in back going with 40 lbs of air instead of 53 lbs for a wider foor print? I seem to be inconsistent at the events and cant make out if it was the track the driver(me) or the tire combo I was tring? :thanks:
2005 dodge 3500, qc, drw, 4x4 flat bed, cummins edge hot w/A2, 5" mbrp turbo back, stage II afe intake, tracton bars, 12000 lbs hitch, BD lift pump, suncoast converter.
http://profile.myspace.com/index.cfm...ndid=352446226
MoPower05 is offline
post #2 of 10 (permalink) Old 09-21-2007, 05:25 PM
try a rough A/T tire or a crossover from a M/T and a A/T like this one http://www.mastercrafttires.com/us/e...ht+Truck+Tires on our dually we run 70psi in the backs and 20psi in the front and so far it has been doing great..
TYREBOYZ_DMAXIN is offline
post #3 of 10 (permalink) Old 09-21-2007, 05:34 PM
pontiacross's Avatar
I think the type of track you pull on makes a big difference as well.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #4 of 10 (permalink) Old 02-04-2008, 11:19 PM
try interco's Trxus STS Mudders all the way around that seems to be the really hot ticket for the duallys at all the pulls i have been at. u might need wheel spacers to make it work but they have great bite
jd_craft is offline
post #5 of 10 (permalink) Old 02-05-2008, 03:38 AM
:iagree the sts' seem to be a hot tire. Just don't use them on the street, the don't last long and they loose the sharp edge that gives them there advantage
Dual K20s is offline
post #6 of 10 (permalink) Old 02-10-2008, 07:27 AM
yep sure do i agree but he will need either well spacers or just put them on to pull with which be the best idea and from the trucks i have seen them let them rub so dirt dont between them and also have more surface area kinda like running one gaint tire
jd_craft is offline
post #7 of 10 (permalink) Old 02-17-2008, 01:48 AM Thread Starter
Thanks for the input I have been getting more consistant since about October figured a few things out. Running more aggresive tires in the front only airing down the rear tires when rule of pull allows the rear springs locked. Next pull I will be tring 10" wide wheels in front. :dodge
post #8 of 10 (permalink) Old 02-17-2008, 11:09 PM
no problem what kinda of surface do pull on
jd_craft is offline
post #9 of 10 (permalink) Old 02-18-2008, 12:43 AM Thread Starter
Many different tracks but mostly clay.
post #10 of 10 (permalink) Old 02-19-2008, 04:20 PM
ok so u have figuered out how to work with the tires u got if u need the more agressie tires go with the tires we suggested
jd_craft is offline
