bigger rims with 36" tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yfz450_0569, this thread has received 1 replies and been viewed 655 times.
post #1 of 2 (permalink) Old 11-17-2007, 03:31 PM Thread Starter
I have a 2007 6.7 liter megacab 3500 cummins and i was thinking about putting some 22.5 inch wheels with 36" tires on it. anyone tried this setup? how do loads pull with it? i pull quite a few and quite heavy loads with it. nearly 50,000 miles in about 3 months and most loads range from 20,000 lbs to one 32,000 lbs and one that was even about 41,000 lbs.
yfz450_0569 is offline
post #2 of 2 (permalink) Old 11-18-2007, 05:46 PM
stillcrazyinlaw's Avatar
Images: 3
Those huge wheels will add alot of unsprung weight to the truck. Those wheels are very heavy,plus I don't know if they would be rated to haul those kind of weights. You might crack them.
stillcrazyinlaw is offline
