2.8 street class - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jd_craft, this thread has received 33 replies and been viewed 2096 times.
post #1 of 34 (permalink) Old 03-12-2008, 12:01 AM Thread Starter
2.8 street class
i am building a truck to run in the 2.8 street class and i am needing help with finding a turbo
jd_craft is offline
post #2 of 34 (permalink) Old 03-12-2008, 12:05 AM
Dodge ford or chev? what engine?
2005 GMC 2500HD 4x4 DMax ZF-6
Blizzard 800 plow, Triple stack of doom
285 BFG mud terrains, Conrad 4" straight pipe, Dynadroit dual disc
Its a work truck
Ben46a is offline
post #3 of 34 (permalink) Old 03-12-2008, 12:09 AM Thread Starter
i a 24 cummins with a p-pump .120 lines 1/2 line from the tank to the pump 14mm p-pump 2.8 inducer size but can be reduced
jd_craft is offline
post #4 of 34 (permalink) Old 03-12-2008, 10:59 AM
Probably an S400, They can be had pretty inexpensivley and seem to spool aily well. Check out www.blackwidowdiesel.com . They have custom turbonetics pulling chargers. Did you check with Scheids or haisleys to see what theyd recommend? Im not much of a cummins guy but thy should be able to help you figure it out. 14mm eh? thats a friggin big pump!
Its a work truck
Ben46a is offline
post #5 of 34 (permalink) Old 03-12-2008, 03:30 PM
2.8 and a 14mm! Ive got one in the classifieds if your interested!
cumminsram is offline
post #6 of 34 (permalink) Old 03-12-2008, 07:14 PM
K31 or aurora 5k
Or you could use a s400 with a bushing
Dual K20s is offline
post #7 of 34 (permalink) Old 03-12-2008, 09:55 PM
Also, you can get a 2.8 cover for an S400 if its a no bushing class.
Its a work truck
Ben46a is offline
post #8 of 34 (permalink) Old 03-12-2008, 11:15 PM Thread Starter
cumminsram the picture u have of ur truck pulling was takin at the rochester indiana fairgrounds been goin to that pull since i was 5
jd_craft is offline
post #9 of 34 (permalink) Old 03-12-2008, 11:19 PM Thread Starter
i can use a bushing on the turbo i am tryin to beable to keep up with terry copress dan mussleman scott amos guys like that
jd_craft is offline
post #10 of 34 (permalink) Old 03-13-2008, 03:38 AM
Go s4. Thats where im goin and it seems thats what everybody else is runnin.
Schied,haisleys, columbus will have em.
U runnin itpa or heavy hitting brush puller?
Whats your other plans for the truck?
