what gear does everyone pull in(auto) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kleiner, this thread has received 19 replies and been viewed 1681 times.
post #1 of 20 (permalink) Old 03-16-2008, 08:03 AM Thread Starter
i usually pull in 2nd gear 4 low but am worried about turning the cummins 4000 rpms. i have already blow one motor. Thats why for any of you that were at stergis and saw me pull i sucked it up at the end, because i was only holing it at 3000rpm. i know im a sissy, but the $12,000 did not come out of any of you guys pockets:deal: :
2006 ram 3500 drw, fully built all billet auto tranny, 5" exhaust, smarty, edge ez, tst, aurora 5000, head studs, sheids cam, ciramic coated pistons, cold air, water meth, fass 150, 100 hp DDP injectors, NX 2 stage nitrous kit, gauges pyro, trans, 100 psi boost, fuel pressure, nitrous pressure
Kleiner is offline
post #2 of 20 (permalink) Old 03-23-2008, 05:50 AM
3rd gear low range
jd_craft is offline
post #3 of 20 (permalink) Old 03-24-2008, 09:42 PM
put the shifter on 2 with the tow haul on. low range 4 wheel drive. thats what i did and she did fine.
cumminsrock is offline
post #4 of 20 (permalink) Old 03-25-2008, 02:39 AM Thread Starter
do u have 4.10's what size tires u run
Kleiner is offline
post #5 of 20 (permalink) Old 03-25-2008, 06:21 AM
u need speed u use torque at the begining of the run to get the sled moving and relay on speed so the truck has an easier time pulling it and then torque at the end of the run to finish the job
jd_craft is offline
post #6 of 20 (permalink) Old 03-28-2008, 04:26 AM
formally dodge97ctd-sc member #12
05dury's Avatar
Send a message via Yahoo to 05dury
what about me...i got a ford with an auto?
2005 chevy 2500 lly duramax extended cab shortbed 4x4...got some go fast stuff done to it
05dury is offline
post #7 of 20 (permalink) Old 03-30-2008, 11:17 PM
soot junkie
I pull in 1st high range. ford99psd, if your sig is up to date you can pull low 2.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #8 of 20 (permalink) Old 03-30-2008, 11:58 PM
i ran 285's at the time and i have 3.73's
post #9 of 20 (permalink) Old 04-01-2008, 01:32 AM
lo 3rd converter locked.
lb7 heaven is offline
post #10 of 20 (permalink) Old 04-01-2008, 03:33 AM
I put 800lbs on the front a Elite sledpulling tune = 420RWHP. Running 33" BFG's I pull it down to 3rd low range, powerbrake on the line and off I go Full wheel speed on the line.
I pulled like 8 pulls in 07 I got 1st 2 times and made 3 or 4 full pulls. I was usally in the top 5. A big pull in east farther I pull in a class of 20 street trucks and took 2nd.
Never ran out of power running 3rd low with the converter locked she spun em hard at the end.
imported_Six_leaker is offline
