Suspension mods to help in pulling...? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 17 replies and been viewed 1996 times.
post #1 of 18 (permalink) Old 03-27-2008, 07:48 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
What types of modifications have you all done or seen that improve getting the sled farther down the track? i am getting pretty decent at drag racing, and love to do that....i havent gotten "hooked" on pulling yet. however i also havent done extremely great either...never can get much traction either.
I was thinking about putting either a 1" or so block in the rear or installing an addleaf for some extra height in the rear...thought it would look cool too and maybe help in pulling...
also adding a set of traction bars
and when actually pulling put some blocks in the rear so it wont squat really bad...
does it matter/make a differnece if the traction bars are mounted to where the leafspring is mounted (like pointacross has, pic in general ford forum under traction bars) or just tabs welded on the rear end..?
anything else short of lockers and more power adders?
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 18 (permalink) Old 03-27-2008, 11:25 PM
Still Strokin
dlopp's Avatar
Do the traction bars. Make you a set of axle stops to keep the truck squating so you dont loose hitch heigth. I made my axle stops asjustable so i could move them from 0 to 1 1/2'' travel if any body got in a fuss over them. IMO Instead of doing the blocks make you a adjustable hitch so you can get as close to 26'' as you can
-02 F-350 6spd, DP Tuner F-6, 300+cc B codes, 150 FASS, two custom s400's, BTS oil, dual disk clutch.
-95 Dodge 12V 5 spd puller
-Tow rig 03 FL-60 Freightliner QC by Sportsshassie, 300hp 3126, 6 spd allison, with propane and a TS chp
-97 ranger 2.3L 5spd
-06 F450 work truck with 11' IMT body
Big Thanks to DP-Tuner and Rosewood Diesel!
dlopp is offline
post #3 of 18 (permalink) Old 03-28-2008, 12:56 AM
SSpeeDEMONSS's Avatar
i would think to make your traction bars longer. put the lift from the bars farther up the frame. and as dlopp said, make sure your hitch is built to be as close to 26" as possible.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #4 of 18 (permalink) Old 03-28-2008, 02:38 AM
i agree use an adjustable hitch try to make ur rear suspension as rigid as possible hang weights on the frint if possible i would go about 48 inches on the length of the traction bars and design is up to u u will have to pull the propane system off ur truck for must pulling groups like the dhra
jd_craft is offline
post #5 of 18 (permalink) Old 03-28-2008, 03:15 AM
Hey Darin you gonna pull at Posey?
lb7 heaven is offline
post #6 of 18 (permalink) Old 03-28-2008, 02:29 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
umm...the traction bars i got are plently long....77" im not planning on making it a puller truck....just would like to know a few simple things to try! thanks for the input guys!
......so basically i had the right idea in the OP, with the bars, blocks, etc. just need to get my hitch height higher! :Thumbup: what about adding some height in the rear too with an addleaf or block...?
Previous Rides:
post #7 of 18 (permalink) Old 03-28-2008, 02:41 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
kyle...if i dont knock you out for askin me so dam many times...:splat laugh :sofa :hehe YES.......as long as my trucks fixed! and hopefully i will have all these mods done and maybe have some technique! ....if you have to operate the sled i for sure will so i can throw some more dirt at ya! : :evil:
Previous Rides:
post #8 of 18 (permalink) Old 03-28-2008, 04:28 PM
Still Strokin
dlopp's Avatar
My :2cents I wouldn't. I would make some bolt on axle stops to keep the truck from squating, that you could take off when your not pulling and build the hitch to be able to reach 26''. That way you dont have to live with the extra springs on there all the time.
dlopp is offline
post #9 of 18 (permalink) Old 03-28-2008, 04:55 PM
In that case i'll run the sled again AND i'll let you use my hitch!
post #10 of 18 (permalink) Old 03-28-2008, 07:46 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
hahaha. aight, that'll work! ...i was going to leave the block in the rear too for looks! i got a level kit on it now so was thinkin bout goin a hair higher in the rear...
thanks guys!
kyle...ill see YOU at the track...and prolly a bunch of times before and after that!
Previous Rides:
