super semi pulling - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jd_craft, this thread has received 19 replies and been viewed 16376 times.
post #1 of 20 (permalink) Old 03-30-2008, 09:41 PM Thread Starter
super semi pulling
does anybody follow the super semi pulling truck i am thinking about building one i really like the trucks of the prohibbited pulling team what do u think is the best motor for my truck
jd_craft is offline
post #2 of 20 (permalink) Old 03-30-2008, 10:06 PM
pontiacross's Avatar
kt1150 cummins seem to be pretty good from what I have seen.
I have also seen a pretty good running 6cly cat but I'm not sure what model it was I think it was bigger than a 3406.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 20 (permalink) Old 03-30-2008, 10:47 PM Thread Starter
well they make a 16L cat and the kt 1150s are hard to find now i was thinkin about running the scheid 12 cylinder pump on the motor
jd_craft is offline
post #4 of 20 (permalink) Old 03-31-2008, 10:09 PM
Well Id think a 15.8 L cat with a pump on it. Even a good 3406B will make big power. V8 macks can make power but also are very finickity engines.
2005 GMC 2500HD 4x4 DMax ZF-6
Blizzard 800 plow, Triple stack of doom
285 BFG mud terrains, Conrad 4" straight pipe, Dynadroit dual disc
Its a work truck
Ben46a is offline
post #5 of 20 (permalink) Old 03-31-2008, 10:36 PM Thread Starter
yeah V8 mack one the title last year but if it got in a loose track it didnt do as good hibbits pulling team has a 3406b and the 600hp edition cat and then 3408 i was thinking the 16 liter cat would be the best then throw the 12 cylinder injection pump on it i was thinking about running quad turbos custom exhaust header they are running like 6 disk clower clutch no cluw what tranny though
jd_craft is offline
post #6 of 20 (permalink) Old 04-01-2008, 12:00 PM
Still Strokin
dlopp's Avatar
A 3406B or C, Or get an old kenworth cabover with a 3408, put a twin turbo setup on it, and turn up the pump.:evil: The Prohibited pulling trucks are bad azz. The one greg drives is a 3406B-C and the other one is a 3406E. I talked to Greg at one pull, he said that he runs 120+lb of boost and comes out of the line at over 4800 rpm, Thats a lot of motor to be turning close to 5000rpm.
-02 F-350 6spd, DP Tuner F-6, 300+cc B codes, 150 FASS, two custom s400's, BTS oil, dual disk clutch.
-95 Dodge 12V 5 spd puller
-Tow rig 03 FL-60 Freightliner QC by Sportsshassie, 300hp 3126, 6 spd allison, with propane and a TS chp
-97 ranger 2.3L 5spd
-06 F450 work truck with 11' IMT body
Big Thanks to DP-Tuner and Rosewood Diesel!
dlopp is offline
post #7 of 20 (permalink) Old 04-01-2008, 09:07 PM Thread Starter
you know they bought the blue ox right they converted it over to 3408 with twins then down graded it to a single i am hopin they make it a quad turbo the W900 is built just for pulling tube chassis that one has the 3406E in it the 3408 with a sigma pump 4 turbos would be wicked and then again on an inline six cat i can run the 12 cyclinder injection pump from scheid
jd_craft is offline
post #8 of 20 (permalink) Old 04-04-2008, 04:02 AM
Hopefully I will be building one. At work we have a 75 Internation Transtar that just sits around. it has a Cummins in it just not sure what. But it will lift the front tire off the ground every shift!
imported_Bosshawg600 is offline
post #9 of 20 (permalink) Old 04-04-2008, 05:02 AM
DieselJuice's Avatar
Our old 379 c16 ppb use to do that fully loaded with grain. God that thing ate clutches and ds u-joints, i remember in arkansas my uncle missed a gear and the engine went crazy and there was nothing but black smoke behind us
-Cody
2002 -Sold
1988 F-250 4x4 7.3L 5spd
DieselJuice is offline
post #10 of 20 (permalink) Old 04-04-2008, 06:58 AM Thread Starter
i would guess that transtar would have an 855 cummins in it and yes they can be built to run strong there is a guy with guy on youtube a pete with a 855 cummins and it was dynoed at 1300hp and th was only one turbo and a p-pump i bet that pete u had was a great truck and power is hard on clutches and u joints weak lins in the power train imgaine one with 4 turbos 2 for every 3 cylinders that is how prohibbited 2 is setup and then i would throw a 12 cylinder scheid diesel injection pump on top of that
jd_craft is offline
