pulling and in what gear - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Got Diesel?i do, this thread has received 8 replies and been viewed 1007 times.
post #1 of 9 (permalink) Old 05-02-2008, 07:46 AM Thread Starter
ok im new to the pulling world...i have the 6speed 24v, i was thinking 1st gear 4 low?
Got Diesel?i do is offline
post #2 of 9 (permalink) Old 05-02-2008, 01:36 PM
01duramax6spd's Avatar
4th gear 4lo is what I use in my D-Max 6spd. If you have 4.10's you might try 5th. I hope you have a dual disc or triple disc clutch?
Edit: after reading your sig,I'm guessing you have plenty of power to run 5th.
01duramax6spd is offline
post #3 of 9 (permalink) Old 05-02-2008, 10:28 PM Thread Starter
wouldnt that lug a lot? and i do have a aftermarket clutch..i thought it would be 1st gear 4lo...why such a high gear?
post #4 of 9 (permalink) Old 05-02-2008, 10:52 PM
Its Cute Aint it!!
4lo and 1st is a crawl you at least need a lil speed. My buddy has the same truck as you and he pulls 4lo and 4th it luggs a lil when he first lets off the clutch but catches up.
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #5 of 9 (permalink) Old 05-02-2008, 11:37 PM
If you have a good double disc iron (feramic) I would try at least 4th low. Take the slack out of the chain, hold it at the governor and start slipping it out. I usually slip mine out until about 50 feet then let it out.
2005 GMC 2500HD 4x4 DMax ZF-6
Blizzard 800 plow, Triple stack of doom
285 BFG mud terrains, Conrad 4" straight pipe, Dynadroit dual disc
Its a work truck
Ben46a is offline
post #6 of 9 (permalink) Old 05-03-2008, 12:52 AM
You probanly pull in 5th like John don't ya?
On topic we with D-Max's are leaving the line at 3500rpm+. John leaves the line at 4800rpm with his D-Max
post #7 of 9 (permalink) Old 05-03-2008, 05:43 AM Thread Starter
all this means a lot to me guys... so let me get this straight... 4 lo 4th gear.... and try and pick up speed?
post #8 of 9 (permalink) Old 05-03-2008, 01:11 PM
Right :Thumbup: . Start at whatever the most RPM you feel comfortable. I'd recommend at least 2500rpm. Slip your clutch a bit till you get moving good,then let it rip
post #9 of 9 (permalink) Old 05-06-2008, 11:41 AM
Destroked
diesel dan's Avatar
With your set up I would choose a gear that tops out at 25-30 mph.
diesel dan is offline
