who has built ther own ladder bars - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 33 replies and been viewed 6405 times.
post #1 of 34 (permalink) Old 01-18-2009, 03:33 PM Thread Starter
vcassens's Avatar
for the guys who have built ther own ladder bars did you guys use solid bars or hollow tubs and if posible can I see some pics of them and how they are atached to the frame and axle also do they have to move at the frame or can they be bolted solid I am wanting to build my own set but want some ideas before I get started thanks and if any body has built a set for the front that wold be great
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 34 (permalink) Old 01-19-2009, 12:05 AM
pontiacross's Avatar
I built my owb with 1.25in. scedual 80 tubeing, unless you are only going to be pulling with them and not running on the street I think a schackle is nessacary on ladderbars
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 34 (permalink) Old 01-19-2009, 12:17 AM
Slow 6.0
a shackle is a must for street use
2006 F350 XLT 4x4
SICKS-O is offline
post #4 of 34 (permalink) Old 01-19-2009, 01:01 AM Thread Starter
vcassens's Avatar
[QUOTE=pontiacross;659126]I built my owb with 1.25in. scedual 80 tubeing, unless you are only going to be pulling with them and not running on the street I think a schackle is nessacary on ladderbars
[/QUOTE
so will they help with anything other than sled pulling and do you have any on the front thanks
singles club #206
bomb squad #67
vcassens is offline
post #5 of 34 (permalink) Old 01-19-2009, 03:06 AM
It was basicly impossible to do a burnout with my truck becasue it wheel hopped so bad. after I built the ladder bars it dosent event wiggle while spinning the tires. I love em.
I havent got any on the front yet but I have been thinking about it. if I do them they will probably be the single bar stile with no schakle, and I will remove them when not pulling.
Ross
Tow Rig
The Following User Says Thank You to pontiacross For this addition to TDG:
vcassens (01-19-2009)
post #6 of 34 (permalink) Old 01-19-2009, 03:24 AM Thread Starter
vcassens's Avatar
so if I did just one single 1.5'' solid bar do you think that wold be strong enogh for every day driving and a sled pull every now and then
singles club #206
bomb squad #67
vcassens is offline
post #7 of 34 (permalink) Old 01-19-2009, 10:05 PM
Still Strokin
dlopp's Avatar
wow, heavy! It would work but I think some thick wall tube would be better, at least 1/4'' wall. Depends on how far you want to get into the pulling deal. Like my truck, that about all it does is pull the sled. I'm runing a single tube-bar 2 1/8'', 5/16 wall, with no shackle and cat. "0" top link ends off of a 3 poit hitch. Don't use cat. "0" use atleast a cat. "1" top link. The cat. "0" is a little small, Ive been a few times by them befor, i got them fixed now tho. If you want some pic's, PM me. For some reason I cant get pics to load on a thread.
-02 F-350 6spd, DP Tuner F-6, 300+cc B codes, 150 FASS, two custom s400's, BTS oil, dual disk clutch.
-95 Dodge 12V 5 spd puller
-Tow rig 03 FL-60 Freightliner QC by Sportsshassie, 300hp 3126, 6 spd allison, with propane and a TS chp
-97 ranger 2.3L 5spd
-06 F450 work truck with 11' IMT body
Big Thanks to DP-Tuner and Rosewood Diesel!
dlopp is offline
The Following User Says Thank You to dlopp For this addition to TDG:
vcassens (01-20-2009)
post #8 of 34 (permalink) Old 01-25-2009, 09:07 PM
TDG Mafia Member#67
6L strokin's Avatar
https://www.thedieselgarage.com/forum...read.php?t=323
lot of pics in this thread...
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #9 of 34 (permalink) Old 01-26-2009, 01:08 AM
SSpeeDEMONSS's Avatar
where do you get cat. 1 top link ends?
ross, what link ends did you use?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #10 of 34 (permalink) Old 01-26-2009, 01:45 AM
I bought an adjustable link at the local farm and home store and then cut it up to make mine.
Ross
Tow Rig
Ladder Bars and Traction Bars Jays7.3 General Ford Truck and Excursion 7 01-24-2008 02:23 AM
Has anybody put a set of ladder bars on yet? Brutus the Grey 6.7L Cummins (2007.5-2011) 0 11-05-2007 06:26 PM
Ladder Bars Extended Power General Ford Truck and Excursion 14 07-01-2007 09:49 PM
Needed...DODGE Ladder Bars & Nerf Bars bigdraft Supporting Vendors Forum 1 04-05-2007 02:53 AM
Need Ladder Bars NMU98 General Ford Truck and Excursion 11 11-22-2005 10:43 PM
