5.9 ProMod 2wd puller - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2wpuller, this thread has received 183 replies and been viewed 30491 times.
post #1 of 184 (permalink) Old 01-27-2009, 06:15 PM Thread Starter
2wpuller's Avatar
2007 GTS fiberglass tilt body with a 6" longer front clip.
5.9 cummins
Twin turbo's
3sp Profab trany
4 disk clutch
4**** clutch can
Large rockwell rear axle with paniteries
Tube chassie
Air guiliteen
The Alarm System
will poast more picture as we progress.
Dale
1975 f250 6.0Perkins,twins,6sp allison.HM.airride,4"ex,Airtilt front clip.
72 chevy 5.9 5sp.
2007 Dodge 2 WD pulling truck
Sponsors
GoerendTransmission
Haisley Machine
MCS MidwestPerformanceDiesel
ShowMePerformance
[/FONT]
2wpuller is offline
post #2 of 184 (permalink) Old 01-27-2009, 11:07 PM
Real Trucks Rattle
Smoketracks's Avatar
Post the pics when you have it done. iT looks like it will be one bad ride when your done!
2006 Dodge Ram 2500 4x4, G56 6 speed, Valair Dual disk, Edge programmer, 100hp sticks, AEM Brute Force intake
1995 12V 4x4, KDP tabbed, Piller gauges, 191 DV'S, 4K GSK, #6 Fuel Plate (Full Forward), AFC Spring, 60# valve and exhaust springs, AEM Brute Force intake, DDP stage II injectors and TCI tranny with converter locker, BD Super B Turbo Charger - It is gone but not forgotten. I will miss that truck! 2006 100hp sticks, edge programmer, AFE intake and southbend dual disk
Smoketracks is offline
post #3 of 184 (permalink) Old 01-28-2009, 01:57 AM
Kyle`s Car Care
forrestk's Avatar
lookin good!
2006 Ford F-250 6.0L
forrestk is offline
post #4 of 184 (permalink) Old 01-28-2009, 03:01 AM
stillcrazyinlaw's Avatar
Images: 3
I dig the tranny. is that air shifted and do you shift it during pulls? My buddy has a profab tranny in his pull truck,it is 1 gear forward and 1 back. I have been thinking about getting something similar.
Great pics
yulan
stillcrazyinlaw is offline
post #5 of 184 (permalink) Old 01-28-2009, 04:31 AM
pontiacross's Avatar
looking good Dale
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #6 of 184 (permalink) Old 01-28-2009, 02:53 PM Thread Starter
2wpuller's Avatar
Great pics
yulan
No it is not air shifted and I don't shift wile pulling The sled opporators don't alow it.This Profab has 3 gears and 1 reverse.
Ross can I bring it up to Mexico and make a exibition hook only cost you a beer
Will be posting more pictures as we do more.
Dale
72 chevy 5.9 5sp.
Sponsors
GoerendTransmission
Haisley Machine
ShowMePerformance
[/FONT]
2wpuller is offline
post #7 of 184 (permalink) Old 01-29-2009, 02:24 AM
Dale
that is fine with me, as long as you have all your saft equipment, but I will have to check with everyone else just to make sure its fine with them.
what kind of beer do you drink, I'll be sure and have a 12 pack
Ross
Tow Rig
post #8 of 184 (permalink) Old 01-29-2009, 03:03 AM
Images: 3
Dale
Just curious
Then do you use the 3 gears for your adjusting for final drive ratios? With mine which is totally different I use my profab t-case for all adjustments.
post #9 of 184 (permalink) Old 01-29-2009, 09:13 PM Thread Starter
2wpuller's Avatar
I just use it for the finnal drive no transfercase.
Dale
72 chevy 5.9 5sp.
Sponsors
GoerendTransmission
Haisley Machine
ShowMePerformance
[/FONT]
2wpuller is offline
post #10 of 184 (permalink) Old 01-29-2009, 09:19 PM Thread Starter
2wpuller's Avatar
We got the bed sides mocked up last night .orderd the tubeing for the frame work for the body so it will tilt.
The charger that we will be useing that I had lyeing around don't have the coins to buy what I need.We are useing a HT4C and a 42 Garet
Dale
72 chevy 5.9 5sp.
Sponsors
GoerendTransmission
Haisley Machine
ShowMePerformance
[/FONT]
2wpuller is offline
Blown Up 12V Puller? RacinDuallie 5.9L Cummins 12 Valve (1994-1998.5) 17 04-12-2006 01:00 PM
New Puller Choke_On_My_Smoke Sled Pulling 7 12-29-2005 07:16 PM
6.0 puller fuzzys69 Sled Pulling 12 11-21-2005 11:59 PM
Puller from the ground up? Paul H Sled Pulling 67 08-08-2005 10:47 PM
