hitch placement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pontiacross, this thread has received 12 replies and been viewed 2593 times.
post #1 of 13 (permalink) Old 02-04-2009, 03:57 AM Thread Starter
pontiacross's Avatar
hitch placement
so I'm getting ready to redo the hitch on my pulling truck. I got a roll pan so I can get the ring as far forward as possible, but to make it all fit and look right I am going to build a new reciever hitch at the same time.
my question is, what is everyones opinion as how and where the new hitch should be bolted on. do I need to bolt the acual reciever hitch as far forward as posible ( centerline of axel per. rules) or is that a waste of time and effort. It seems to me that if the ring is going to be at 26in. high and just behind the tailgate the leverage would be the same no mater where the rest of the hitch is bolted on. or am I looking at it wrong.
has anyone done any testing on this?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #2 of 13 (permalink) Old 02-04-2009, 04:07 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
All of the trucks that I have came across in the years all had the hitch further up under the truck as you are thinking, I do believe their is a gain to it, but how much I am not sure. Does the rules state that it has to be in a reciever style hitch? If not build a bad aZZ hitch. If it does I would stay with reciever style located near the back.
POWER STROKE 99 is offline
The Following User Says Thank You to POWER STROKE 99 For this addition to TDG:
pontiacross (02-04-2009)
post #3 of 13 (permalink) Old 02-04-2009, 04:10 AM Thread Starter
it must be a reciever stile hitch.
Ross
Tow Rig
post #4 of 13 (permalink) Old 02-04-2009, 04:15 PM
SSpeeDEMONSS's Avatar
the farther you can mount it forward the more leverage it does have.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
post #5 of 13 (permalink) Old 02-04-2009, 05:35 PM
2wpuller's Avatar
It's not that the short hitch has more leverage if the hitch is back further it will load the back tires harder but it will also try to lift the front of the ground easier that is why you move the hitch closer to the rear end.don't have asmuch everage to try to lift the front.so the front help pull alot more with a short one.
Dale
1975 f250 6.0Perkins,twins,6sp allison.HM.airride,4"ex,Airtilt front clip.
72 chevy 5.9 5sp.
2007 Dodge 2 WD pulling truck
Sponsors
GoerendTransmission
Haisley Machine
MCS MidwestPerformanceDiesel
ShowMePerformance
[/FONT]
2wpuller is offline
The Following User Says Thank You to 2wpuller For this addition to TDG:
post #6 of 13 (permalink) Old 02-05-2009, 03:26 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
wheres wayne and his bad hitch?
Jordan
blackcloudCTD95 is offline
post #7 of 13 (permalink) Old 02-05-2009, 02:34 PM
2wpuller's Avatar
Your welcome Ross
Dale
72 chevy 5.9 5sp.
Sponsors
GoerendTransmission
Haisley Machine
ShowMePerformance
[/FONT]
2wpuller is offline
post #8 of 13 (permalink) Old 02-11-2009, 03:51 PM
Administrator
fordt's Avatar
Images: 5
I don't know how BAD it is, but I like it.
The backside of the ring is the furthest point on the truck by about 1"-2".
OEM bumper and hitch removed -
Slugger - electromagnet base
Fitment -
Drilling Frame -
Primed, and attached -
Almost Finished -
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #9 of 13 (permalink) Old 02-11-2009, 06:30 PM
wayne, how much higher is that than the stock? and what else is different?
post #10 of 13 (permalink) Old 02-11-2009, 06:52 PM
Administrator
fordt's Avatar
Images: 5
By the time you figure the extra weight of the hitch, and minus the bumoer I am sure it equals out ot about the same.
The hitch is moved about as far forward as it can be. It might be moved forward another few inches, but it fit well where it is.
-Wayne
fordt is offline
pyro placement exoticsrnw Dodge Performance Forum 7 12-29-2007 01:49 PM
Ford factory trailer hitch vs. Class V hitch - questions Offshore1 2008-2010 6.4L Power Stroke 6 10-24-2007 10:27 PM
Fuel filter placement... bakantor 2003-2007 6.0L Power Stroke 5 09-27-2007 10:09 PM
Best EGT setup and placement brbrown 2003-2007 6.0L Power Stroke 14 04-20-2007 03:25 AM
SCT Emblem Placement? cmkworm 2003-2007 6.0L Power Stroke 9 05-22-2006 02:52 AM
