pic of drive shaft loops and uni guards? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droolinforparts, this thread has received 19 replies and been viewed 5749 times.
post #1 of 20 (permalink) Old 03-31-2009, 08:29 PM Thread Starter
droolinforparts's Avatar
Send a message via AIM to droolinforparts
i need to build some so i need ideas
'03 F250 XL 6.0LK&N intake, mbrp 5" stacks, SCT X3 with tunes from innovative, 6" superlift, 315-75r-16,boost, pyro, fuel pressure, oil pressure gauges all in the a-pillar,h-11 studs, short throw shifter,fass 95/150 with complete custom fuel lines, south bend clutch, traction bars
Singles #118
B.O.M.B Squad #28
droolinforparts is offline
post #2 of 20 (permalink) Old 04-01-2009, 08:17 PM
SSpeeDEMONSS's Avatar
if you do a search you can find A LOT of stuff.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 20 (permalink) Old 04-01-2009, 10:48 PM Thread Starter
ok thanks garrett
Singles #118
B.O.M.B Squad #28
post #4 of 20 (permalink) Old 04-02-2009, 02:01 AM
try this too.
http://images.google.com/images?sour...-8&sa=N&tab=wi
post #5 of 20 (permalink) Old 04-03-2009, 10:44 PM
just make sure you check your local rules for thickness
03strokerGavin is offline
post #6 of 20 (permalink) Old 04-06-2009, 03:07 PM
2wpuller's Avatar
Alot of rule that I have found say 5/16 thick
Dale
1975 f250 6.0Perkins,twins,6sp allison.HM.airride,4"ex,Airtilt front clip.
72 chevy 5.9 5sp.
2007 Dodge 2 WD pulling truck
Sponsors
GoerendTransmission
Haisley Machine
MCS MidwestPerformanceDiesel
ShowMePerformance
[/FONT]
2wpuller is offline
post #7 of 20 (permalink) Old 04-07-2009, 01:07 AM Thread Starter
ok thanks guys
Singles #118
B.O.M.B Squad #28
post #8 of 20 (permalink) Old 04-07-2009, 01:59 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Garrett, if that is your truck nice job looks good.
POWER STROKE 99 is offline
post #9 of 20 (permalink) Old 04-07-2009, 07:18 PM
haha, no. i can only dream stuff on my truck is as nice as the always famous BBD.
post #10 of 20 (permalink) Old 04-07-2009, 09:29 PM
I was not sure.....looks good though.......I started building a set almost like that but have never finished.
Front Drive Axle Inner Shaft and Inner Shaft Housing Replacement (8.25 S4WD and 9.25 ripmf666 GM Spec Info 0 12-28-2008 11:10 AM
where do i get a Drive shaft? cummins9185 5.9L Cummins 12 Valve (1994-1998.5) 4 04-18-2008 03:29 AM
Drive Shaft cope junkie 5.9L Cummins (2003-2007.5) 5 02-13-2008 08:08 PM
info on billet drive shaft loops nastys6.0 2003-2007 6.0L Power Stroke 1 11-19-2007 01:55 AM
Drive Shaft crfracer Whats Been Sold 0 11-09-2007 08:56 AM
