break-away switch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vader's fury, this thread has received 3 replies and been viewed 1159 times.
post #1 of 4 (permalink) Old 06-25-2009, 09:41 PM Thread Starter
beware the dark side
break-away switch
anyone have a set up for killing the truck when sled pullin. some of the pulls around here are talkin bout making this manditory so if the truck breaks free of the sled it shuts down. I have a few idea's but just wondering if anyone has set this up before. My truck is listed below.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #2 of 4 (permalink) Old 06-29-2009, 10:37 PM
Wanna be door swinger
pullingtrucker's Avatar
Send a message via Yahoo to pullingtrucker
Don't know how you could set it up on the diesel pickups, but for our gas pulling truck we just use a simple set of 110volt male and female plugs. We wired it to kill the power going to the coil by running the power back to the female plug were it has to go through to male plugs prong and a wire is ran to the other terminal on the male plug and back up to the coil. Simple and effective with no complaints so far. Just make sure that the "jumper wire" on the male plug is secured good and give it a few wraps of electrical tape to be safe. I can post pics up in a couple of days if ya want.
'06 379 Peterbilt with a C-15 MXS 550hp, 200gph FASS, high flow mufflers, fuel harness, shimmed fuel pump, crankshaft balancer, Bully Dog Big Rig downloader, Bully Dog exhuast manifold, Spinner II bypass filter , a big Detroit Radiator, custom built Lipe clutch, Schaeffer's synthetics in all boxes, and a 18 speed tranny.
'06 53' Utility 3000R with a Carrier unit hanging on the nose. Just a plain trailer with little frills.
Ridin Dirty Club #12
pullingtrucker is offline
post #3 of 4 (permalink) Old 06-30-2009, 02:04 AM Thread Starter
i was thinking of using a similar idea with just a regular 2 prong 12v plug and just looping one side of the plug so when unplugged it will kell power just like turning off the key. Just working on finding the right wire to tap into so will work properly. also figure will work for a good theft deterent if i ever have to leave my truck somewhere questionable. just take the plug off and put it in my pocket and you cant start truck.
post #4 of 4 (permalink) Old 07-10-2009, 04:01 AM
BigBadDodge
BigBadDodge's Avatar
Most diesel orginasations require the kill switch to activate an air guilitine killing the electrical power will do nothing in the event of a runaway either get an air guiltine.
BBD
Additional Team Members
Fluidampr.com
SouthBendClutch.com
Ponci's Diesel Center
Northwesternservice.com
Reality Custom Painting
WoodruffDiesel.com
Watson Performance Engineering
AirDog
BigBadDodge is offline
What would cause the starter bolts to break and the starter to break in half? Rgdl 2003-2007 6.0L Power Stroke 15 06-20-2009 01:18 AM
2nd Break In coop0616 2008-2010 6.4L Power Stroke 28 05-19-2009 11:03 PM
Key pad break in mmayo 2008-2010 Body & Suspension 16 01-21-2009 06:11 PM
Break-in/mpg whitestroke 6.7L Cummins (2007.5-2011) 0 08-31-2007 02:51 PM
So, how did you break your arm? BIGHILLBILLY The Parking Lot 9 01-30-2007 11:06 PM
