Please help spartan - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AlloutStrokin, this thread has received 8 replies and been viewed 1231 times.
post #1 of 9 (permalink) Old 06-26-2010, 05:02 AM Thread Starter
Please help spartan
I just bought a Spartan and I'm having probs. Ran it two weeks on 150 Dpf on. Just installed turboback delete and age stage 2. I loaded the 250 tune. Turned key off for 10 seconds and started. Did trans relearn and truck ran awesome. Got back to the house turned truck off! Got in it to go to a buddys house 20 min later and it wouldn't start. Would do absolutly nothing. Reprogramed back to stock. As soon as I completed heard fuel pump come on. Loaded the 150 Dpf off tune. Started right up and ran great. Turned ignition off and the same thing happend wouldn't start, turn over nothing. Can sombody please give me a call with input! 979-240-4027
AlloutStrokin is offline
post #2 of 9 (permalink) Old 06-26-2010, 02:44 PM
When installing the DPF delete, you probably left one of the temperature sensors unplugged or otherwise mangled the electrical to have it go open circuit. This causes them to read high (ie, way over temp) and may prevent the truck from starting since it thinks the exhaust is super hot. Check all the temp sensors in the exhaust and their connectors.
kschmidt64 is offline
post #3 of 9 (permalink) Old 06-26-2010, 06:12 PM
Boaz's Avatar
The sensors are easy to break. I broke one going back to stock once dealer asked a lot of questions W,W,W,W,and H about tuners before correcting under warranty.
2008 Job 1 F250 CC 4X4 SB Stock
Boaz is offline
post #4 of 9 (permalink) Old 06-26-2010, 07:54 PM
Spartan Diesel Tech
08stroker250's Avatar
If it was a temp sensor it wouldn't start period....at least that is my experience with it. Are there any codes?
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #5 of 9 (permalink) Old 06-26-2010, 11:31 PM Thread Starter
I reprogrammed it with the 250 tune while I was installing the flo-pro downpipe back exhaust, and afe intake. It said turn key off for 10 seconds and start. I did I fired up and ran excellent. I have to reprogram everytime for it to start. The light on the dash come on but when you turn the key I does nothing. Won't even turn over. The exaust didn't come with anywhere to plug in sensors they are just unpluged under the truck. Is this the problem
post #6 of 9 (permalink) Old 06-26-2010, 11:36 PM
Spartan Diesel Tech
The exhaust should have bungs in it for the sensors. If the sensors are not plugged in then that is why your truck doesn't start. Who did you order everything from?
post #7 of 9 (permalink) Old 06-27-2010, 04:24 PM Thread Starter
I drilled holes and weleded in bungs. Hooked up sensors, now it starts everytime, thought it needed the bungs but he the guy I bought it from insisted it didn't. Thanks everybody for the help. Im gonna run the 250 tune for awhile. Will the shifting get better. When I was doing the relearn, I floored it and It seemed as if it was missing gears or slipping on trans. Is this normal. Sorry bout all the question nobody around here has ever heard of Spartan.
post #8 of 9 (permalink) Old 06-28-2010, 08:08 PM
Spartan Diesel Tech
Missing gears is not normal.
PM me who you bought your kit from please. Thanks!
post #9 of 9 (permalink) Old 06-30-2010, 12:02 PM
S10
Built not bought...
Well I must live pretty close since u have a 979 area code.
S10 is offline
Big thanks to Spartan!!! BeauxPete 2008-2010 6.4L Engine Tuner Forum 6 05-03-2010 01:33 AM
Anyone have both the Spartan 310 and RCD 585 Klutch 2008-2010 6.4L Engine Tuner Forum 3 08-01-2009 06:33 PM
Fun with spartan lol 03f3507.3 2008-2010 6.4L Engine Tuner Forum 6 06-17-2009 11:33 PM
Spartan o5 stroker 2008-2010 6.4L Engine Tuner Forum 8 06-15-2009 05:23 PM
Used Spartan. themidship22 2008-2010 6.4L Engine Tuner Forum 1 04-21-2009 04:55 AM
