Alright Guys, I got some noobie questions that i need answered - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by xnissanxminisx, this thread has received 4 replies and been viewed 944 times.
post #1 of 5 (permalink) Old 07-13-2010, 05:36 AM Thread Starter
xnissanxminisx's Avatar
first off, im getting the spartan tuner put on my truck with a AFE Stage II Intake and 4" Exhaust with 6" tip
I know that the first spartan upload takes a pretty good while, but then after that and you want to change your tuning how longs the wait?
What is EGR and Regeneration?
and i believe ill be able to turn them off with the spartan, what will that do for me?
When i put my tuner on do i have to do the Tranny Relearn on it?
and how to i go about doing that?
i red the process but is there a button of feature on the tuner for it?
will i expect less turbo lag and better throttle response with the 250,275, and 310 tunes?
and ive got one other question, theres a guy that wants to race me with a little single cab 4x4 F350 6.0 i beleive hes got a high performance oil pump, and a bigger turbo and intake and full exhaust with water/meth injection
said he ran 8.5 in the 1/8 mile
how would i hold up to that in my CC/SB 6.4 with 310 tune?
Thanks and all help and info in appreciated
-2008 Ford F250 King Ranch-
-6" Fabtech Lift-
-20" Eagle Alloys Powdercoated-
-37" Pro Comp Extremes-
-Spartan 310 Tuned-
-AFE Stage II Intake-
-AFE 4" Straight Piped Exhaust, 8" MBRP Black Stack-
-Recon Smoked Cab Lights-
-Smoke Tail Lights, Side Markers, 3rd Brake-
xnissanxminisx is offline
post #2 of 5 (permalink) Old 07-13-2010, 05:40 AM Thread Starter
Also looking for alot of black smoke, will messing with the EGR affect that?
-6" Fabtech Lift-
-Spartan 310 Tuned-
post #3 of 5 (permalink) Old 07-13-2010, 06:37 PM
Spartan Diesel Tech
08stroker250's Avatar
Answers are in bold
They typically take 15 mins to load
EGR= Exhaust Gas Recirculation, it basically cycle your exhaust back through your motor via the EGR system before dumping it out of the exhaust. It helps produce less emissions.
Regeneration is what your truck does with the DPF on. It basically burns up all the soot using diesel fuel and high heat.
Turning them off will make your truck run more efficient and get better fuel mileage.
You always need to do a transmission relearn with the higher tunes. Just go out and do 3 passes 0-60 at part throttle and 3 passes 0-60 at WOT.
No button, you do it with your right foot.
You will see much less turbo lag and a lot better throttle response
It's hard to say....you would need to launch really good with your big ole tires. It's possible though.
Lastly, you will get PLENTY of black smoke with the 250, 275, and 310 tunes.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
The Following User Says Thank You to 08stroker250 For this addition to TDG:
xnissanxminisx (07-13-2010)
post #4 of 5 (permalink) Old 07-13-2010, 07:06 PM Thread Starter
thanks for all the help man
-6" Fabtech Lift-
-Spartan 310 Tuned-
post #5 of 5 (permalink) Old 07-13-2010, 08:14 PM
Spartan Diesel Tech
Anytime bro!
Alright guys got a friend looking into buying 1st diesel SOOTBANDIT 6.5L Diesel Engine 1 12-14-2009 11:24 PM
alright guys how much do you like the 6.7?? powersmoke18 6.7L Cummins (2007.5-2011) 12 01-23-2008 01:25 AM
Aftermarket exhaust questions answered... BeauxPete 2008-2010 6.4L Power Stroke 4 10-06-2007 03:54 PM
2 Questions for you guys.... pedro_8149 7.3L and 6.9 IDI (Pre 1994) 8 07-23-2007 08:04 AM
Some questions for you guys noreaster 2003-2007 6.0L Power Stroke 10 12-13-2005 06:53 PM
