Making the Move - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselOnly, this thread has received 8 replies and been viewed 864 times.
post #1 of 9 (permalink) Old 07-14-2010, 01:59 AM Thread Starter
DieselOnly's Avatar
Making the Move
Just ordered a spartan tuner tonight. Didn't plan on going above the 210 tune but the more I keep thinking the 250 is looking sweeter. Know I gotta get an Air intake right? Did the search and didn't come up with much. Any ones better than the others and which ones to steer clear of ? I do a lot of towing with this truck also, Heavy toy hauler 5th wheel towing. Do u think I could still tow with the 250?
08 F-350 CC 6.4 4X4.
10 Fuzion TE II Toy Hauler
07 Can-Am 800xt outlander
08 Can-Am 500 Renegade
DieselOnly is offline
post #2 of 9 (permalink) Old 07-14-2010, 02:12 AM
Spartan Diesel Tech
08stroker250's Avatar
I recommend the AFE Stage II intakes. Any of the filters will work, but the Pro Guard 7 seems to be the best. The S&B intakes are also good, but the AFE is much easier to clean and install. That makes the price difference worth it in my opinion.
And yes, you can tow with the 250 tune. You just have to be very watchful of your temps.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 9 (permalink) Old 07-14-2010, 02:46 AM
O2ShootTheJ's Avatar
I heard afe just came out with a new intake called the si or something? might want to check that out
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #4 of 9 (permalink) Old 07-14-2010, 02:47 AM Thread Starter
DieselOnly's Avatar
As in temps, are u referring to egt's? Running stock now and seeing high 11's depending on grade for egt's. tranny temps are good and haven't been higher than 225 at times on engine temp as fan seems to kick on around 221 give or take a few. I just let off the pedal and let myself get to the top as I'm in no hurry.
post #5 of 9 (permalink) Old 07-14-2010, 02:50 AM
Spartan Diesel Tech
Engine oil temps, engine coolant temps, tranny temps, and exhaust temps.
post #6 of 9 (permalink) Old 07-14-2010, 02:59 AM Thread Starter
DieselOnly's Avatar
I did see that one tonight. High price tag also.
post #7 of 9 (permalink) Old 07-14-2010, 03:01 AM Thread Starter
DieselOnly's Avatar
The temps I posted above, do you think they are high for just being stock? Pull a lot of hills around my neck of the woods.
post #8 of 9 (permalink) Old 07-14-2010, 03:30 AM
Spartan Diesel Tech
Yea, I would prefer to not see the tranny temp over 220 degrees ever, but some say its ok to get higher than that for a short period of time. I personally have never seen above 185-190 with mine, even before the Suncoast and deep pan. I also don't tow, just am really hard on my truck. If your under 230 with ECT and EOT, you are typically fine as long as those temps are sustained for a long period of time. You also want to make sure that ECT and EOT stay pretty close to each other. If EOT's starting getting way above ECT, there could be a problem with your oil cooler. If ECT's go up rapidly, it could be head gaskets, your EGR cooler could be flash boiling, your thermostat could be bad, or you could be leaking coolant from somewhere (like the radiator or radiator hose).
post #9 of 9 (permalink) Old 07-14-2010, 03:49 AM Thread Starter
DieselOnly's Avatar
tranny temps never went over 180. My fault, wording was not stated right. ECT's around 221 or 225.
HOW Do I Move This???????? bigdraft The Parking Lot 20 07-03-2009 12:53 AM
North Georgia, making the move R-muck The Parking Lot 13 07-15-2007 09:42 PM
Move over H1..here comes the MXT nummit The Parking Lot 8 02-10-2006 10:28 PM
