IDP Xrace 1/8th - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 3 replies and been viewed 1046 times.
post #1 of 4 (permalink) Old 08-02-2010, 05:17 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
IDP Xrace 1/8th
mods in sig.. couldnt get a good hook/ 60 foot.. spun through first gear in 4x4 on this pass... going to go again when i get some smaller a/t tires instead of a 35" m/t and see if i can knock off 1-2 tenths..
1.81 60ft
8.390 1/8
82 mph
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 4 (permalink) Old 08-02-2010, 06:26 PM
strokin6L's Avatar
Thats still a very good time Darin. Especially for how much the truck weights and only haveing an intake, exhaust and SCT for mods. Put a lil NOS in the mix and get that pig into the high 7's. Nice job.
strokin6L is offline
post #3 of 4 (permalink) Old 08-02-2010, 06:35 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
talked to eric about it and he said pretty much with a little cooler outside temp and some smaller tires that will actualy hook (either street or a/t) itll shave a couple tenths off easy... probably going to go to the 1/4 when i get new tires... she really starts moving when it hits OD before passin the 1/8th...
Previous Rides:
post #4 of 4 (permalink) Old 08-02-2010, 11:29 PM
InnovativeDiesel's Avatar
Images: 1
Good run, that's about a 13.0 or so. We've seen 12.6-12.8 so you are right there with the heat and larger tires.
InnovativeDiesel is offline
The Following User Says Thank You to InnovativeDiesel For this addition to TDG:
6L strokin (08-03-2010)
