350 vs 310 Smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smurfz, this thread has received 6 replies and been viewed 1561 times.
post #1 of 7 (permalink) Old 08-03-2010, 07:57 PM Thread Starter
Super *********
smurfz's Avatar
350 vs 310 Smoke
I have the 310 and found it to be too smokey to be a daily driver. I run the 275 and have for the past 100,000
Can someone tell me if the 350 is more or less SMOKE?
Thx
BigTruck, Some Mods Blah Blah (Oh Yeah Spartan Tuned! with the 310, TCM and Fully Powestroked from the Turbo back!)
Canadian Club Member # 13
smurfz is offline
post #2 of 7 (permalink) Old 08-03-2010, 10:22 PM
Green Goose No Juice
From what ive seen, the two higher tunes than the 310 seem to clean up better than the 310 once the turbos start up..
2010 F250 Lariat FX4 w/Sync.. Everything but nav and sunroof.. Little bit of IDP to help it out
WoodBoy is offline
The Following User Says Thank You to WoodBoy For this addition to TDG:
smurfz (08-03-2010)
post #3 of 7 (permalink) Old 08-03-2010, 11:07 PM
Spartan Diesel Tech
08stroker250's Avatar
On the street, the 350 is smokey. At the track, it doesn't smoke near as much as the 310.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
The Following User Says Thank You to 08stroker250 For this addition to TDG:
smurfz (08-03-2010)
post #4 of 7 (permalink) Old 08-03-2010, 11:50 PM Thread Starter
Super *********
smurfz's Avatar
Well I have a cracked Flex pipe so my turbos take forever to spool. My truck smokes like a freight train!!!
smurfz is offline
post #5 of 7 (permalink) Old 08-04-2010, 12:54 AM
Spartan Diesel Tech
Is it the flex pipe on the uppipe? That is a common issue and requires cab off at the dealership....unfortunately.
post #6 of 7 (permalink) Old 08-04-2010, 12:59 AM Thread Starter
Super *********
smurfz's Avatar
Dealer quoted $ 3000.00 to fix? Cab off for sure. I am living with the smoke for now! Not sure which pipe it is as I can't see
smurfz is offline
post #7 of 7 (permalink) Old 08-10-2010, 04:49 AM
Gerry's Avatar
Sup smurfz,
My passenger side flex pipe developed a small hole last spring and it doesn't 100% require the cab to come off to fix it. Mine went at approx 26k and they have two options to fix it, cab off or drop the tranny and for me they picked dropping the tranny because it was cheaper. Do a search for my name on the Spartan forums and you'll find my post with all the part numbers and costs.
If I remember right the total cost to fix it was about $700 so just make plans for a trip to FL and have it fixed along the way .
Gerry
'08 F-350 Lariat - 6.4L Auto, Crew Cab, DRW, long bed, 4x2 and 4.10 gears.
'08 F-350 Lariat Racing - 13.63 @ 101.7 mph with a 2.24 60
Modifications include DOC/DPF delete pipe, S&B Intake and Spartan tuning.
Gerry is offline
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-06-2009 12:11 AM
white smoke vs. black smoke DUMPIN99 1994-2003 7.3L Power Stroke 20 03-08-2008 12:01 AM
stock truck blowing smoke ( black smoke ) Sabbath5.9 2008-2010 6.4L Power Stroke 11 02-18-2008 03:17 AM
Smoke!!! I Want My Truck To Smoke!!! Mikey00F250 1994-2003 7.3L Power Stroke 15 01-26-2008 10:18 PM
