Cold Side Intercooler Pie...HELP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bighurt, this thread has received 13 replies and been viewed 4526 times.
post #1 of 14 (permalink) Old 08-13-2010, 03:03 AM Thread Starter
I got everything in and routed with one problem. The original boot from the IC to the pipe won't go on the IC pipe. The bead on the inside and the bung on the pipe fit but there isn't enough boot to use the stock clamp band. It just slides off...down the pipe.
I thought about cutting a metal ring to let the boot slide down the pipe farther hoping that would help but I'm not sure.
Anybody?
I can order new boots if that is the answer but I have to have the truck running by sat...would like to have it running tomorrow.
I can message my cell if anyone has advice.
Jeremy
Jeremy Payne
2010 Heartland Sundance 3300RLB
2009 XLT F150 Super Crew Short Box 4x4 5.4L[
2008 Lariat F350 Crew Cab Long Box 4x4 6.4L
-Spartan tuned, S&B Cold Air Intake, Cold side Intercooler pipe, 4" Down pipe, Powerstroker67 DPF/CAT delete, MBRP 4" Black Series w/5" tip.
2005 Yamaha R6
1971 M35A2 AM General W/O Winch
Bighurt is offline
post #2 of 14 (permalink) Old 08-13-2010, 08:01 AM
Can you loosen the clamp on the intercooler side and fudge the boot over a little?
cartmanea is offline
post #3 of 14 (permalink) Old 08-13-2010, 01:33 PM Thread Starter
No
the metal tension rings around the middle prevent the boot from sliding farther down the pipe. They are smaller than the pipe.
Jeremy Payne
2005 Yamaha R6
Bighurt is offline
post #4 of 14 (permalink) Old 08-13-2010, 04:32 PM Thread Starter
Alright I talked to Shawn at Rudy's and he says in order to get the OEM boot to fit properly you need to remove one tension band from the OEM boot. This will allow the boot to slide over the pipe and allow the clamp to actually work.
He says the Cold Side Intercooler pipe was designed for the aftermarket striaght boots.
So monday when Rudy's opens I'll be ordering a new set, but until then the modification above will have to work.
Hope this helps others...
Jeremy Payne
2005 Yamaha R6
Bighurt is offline
post #5 of 14 (permalink) Old 08-13-2010, 10:44 PM
ipkyss's Avatar
After having this same issue myself, I took one ring off and it worked fine. But to anyone else that is upgrading the intercooler line. Just get the dieselsite boots before you upgrade. Its 10 times easier to get the pipe in.
New Ride 08 F-250 CC SB FX-4 6.4 auto loaded job 1, Spartan 310,RCD 485,525, Erics Xstreet,KEM250 DPF delete,downpipe, intercooler pipe, 4" mbrp, timbrens
04 F-350 6.0,auto,SC,SB, 8ft Fisher X-Blade, Hideaway Strobes, XM Radio,Alpine Head unit, X-codes, Edge Mini spring pack, Edge adjustable track bar, 315/75/16 Toyo A/t,Prodigy brake controler,MBRP 3.5" downpipe,5"stacks, powermaxx turbo, Xrace tuned
Old truck-3/27/03 build F-350,CC,SB,DRW 6.0, Auto, Black on black, Blacked out bumpers/ grill, Moon roof, fifth wheel.
old sick, 1/7/03 build
2003 F-350,SC,SB,6.0, 4" lift 37 MT/R
http://community.webshots.com/user/traxx400-date
http://s601.photobucket.com/albums/t...0Ford%20F-250/
ipkyss is offline
post #6 of 14 (permalink) Old 08-18-2010, 01:53 AM
So what's the advantage of this pipe? I only have an AFE intake and didn't know if this would be of some benefit. I have SERIOUS turbo lag!
-Funkster-
2008 F350, 4X4, Crewcab, Long Bed, 6.4L, AFE Intake w/torque tube, 35/12.50/20's on Factory Wheels. Dark Blue Pearl wPueblo Gold Lower Accent.
Funkster is offline
post #7 of 14 (permalink) Old 08-18-2010, 04:33 AM
It all depends on which pipe you use. The one we sell works perfectly with the stock boots which are holding 60 psi no problem.
dfuser is offline
post #8 of 14 (permalink) Old 08-18-2010, 08:05 PM Thread Starter
-Funkster-
I noticed an increase in throttle response...
Jeremy Payne
2005 Yamaha R6
Bighurt is offline
post #9 of 14 (permalink) Old 08-18-2010, 09:10 PM
TexasTruck's Avatar
Images: 1
You don't need to remove it. Simply slide the ring on the pipe side over the bulge in the hose to the ring closest to the intercooler. This leaves two rings on the intercooler side of the bulge incase you want to return to the stock pipe.
2008 Silver CC FX4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness
TexasTruck is offline
post #10 of 14 (permalink) Old 08-18-2010, 09:31 PM
TexasTruck's Avatar
Images: 1
-Funkster-
I noticed 100* drop in EGT. I also noticed a bit of a old school V8 sound like when you flipped the breather lid up side down on a 4 bbl carb - Whaaaa. Other than that, I didn't experiance anything else.
In fact, I took it off.
2008 Silver CC FX4
6.4L Ford Cold SIde Intercooler tube Group Buy. BogginF350 Supporting Vendors Forum 29 10-03-2009 06:19 PM
Cold side intercooler pipe floyd 2008-2010 6.4L Power Stroke 3 06-30-2009 09:37 PM
routing MAP to the hot side... AND cold side? Sleeperstroke 1994-2003 7.3L Power Stroke 2 06-20-2009 01:24 AM
04+ CR cold side intercooler pipe Robts Whats Been Sold 0 03-02-2009 04:05 AM
size of opening on stock intercooler(cold side) strokin6L 2003-2007 6.0L Power Stroke 1 11-20-2007 08:37 PM
