Turbo boots - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by broth, this thread has received 30 replies and been viewed 5395 times.
post #1 of 31 (permalink) Old 08-30-2010, 03:30 AM Thread Starter
Turbo boots
Anybody still having problems blowing or tearing boots? I have tried the dieselsite boots and tore them...stock ones have held up better but did blow and tear a few. I am now trying a set from Riff Raff diesel out of Oregon. We will see how they hold. Just wondering for those that have had problems and suggestions. I can blow/tear them with as little as 30PSI of boost. I am running the spartan most 210 and have tried 75 & 150 with the same luck. Seems to only happen when I pull my 40' toyhauler but leaves you stranded and it sucks.
Thanks in advance.
broth is offline
post #2 of 31 (permalink) Old 08-30-2010, 04:23 AM
Spartan Diesel Tech
08stroker250's Avatar
What was the most recent set of DieselSite boots that you tore? They have redesigned them and Bob is pretty good about standing behind his product. I bought his 6.4 boot kit at TS this year after shredding a boot make the 6% grade climb up to Monteagle, TN on the way to Bowling Green....with nothing behind the truck lol. I haven't had a single issue with them. He told me if I tore his boot to let him know, and he would send me a new set.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 31 (permalink) Old 08-30-2010, 04:18 PM
Martin #6's Avatar
I keep a set of the Riff Raff boots in the truck for whenever the stockers decide to blow.
2008 Job 3 F-250 Lariat CC 4x4
Spartan tunes, S&B intake, Banks IC, RCD cold side pipe, powerstroker67 4" DP & delete pipe to 4" straight exhaust, Suncoast Direct Solenoid, RetroSolutions HID's, Firestone Airbags.
Martin #6 is offline
post #4 of 31 (permalink) Old 08-31-2010, 02:45 PM
O2ShootTheJ's Avatar
good to know, b/c I bought the old style boots off of gihanna6.4 wayy back when he got rid of his 6.4
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #5 of 31 (permalink) Old 08-31-2010, 05:30 PM Thread Starter
08stroker you are correct I did have an old style boot and Bob was very good and helpful. I have the Riff Raff boots on now so we will see how they hold up. If they fail maybe I will give Dieselsite another shot (FYI this is not a bag on Dieselsite products they have reinbursed me and stood behind their product) I just want to dam things to stay together! I have a truck on 37's and pull a good load but I never boost over 35-40psi and never run anything higher that than 210 setting. I seems like guys are much harder on their rig than me yet the boots keep tearing or blowing off. I have put a longer boot on the top hotside so I double clamp both top and bottom hot side now to try to reduce the boot from blowing off but I am thinking that one will tear again now???We shall see I guess. Is there anything that could be wrong with my truck that would cause mine to have more problems than others? Thanks again for the help!!!
broth is offline
post #6 of 31 (permalink) Old 08-31-2010, 11:21 PM
Is "blowing" or "tearing" a turbo boot very common?
I run the 250 as a daily driver and also use it for towing my 5th wheel (24' & 7,000#s) and sometimes double tow my bass boat (another 5,000 #s).
My truck is a 2010 model.
Truckmaniac is offline
post #7 of 31 (permalink) Old 08-31-2010, 11:47 PM Thread Starter
It is for me!
broth is offline
post #8 of 31 (permalink) Old 09-01-2010, 01:33 AM
Spartan Diesel Tech
I went 78,000 miles on my original stock ones. I hit the 6% grade, switched 2 lanes over, rolled in to the throttle, and BAM!!! It sounded like a shot gun went off and then came the thickest black smoke I have ever seen out of the tail pipe. It was RIDICULOUS
I probably hit 45-48 psi of boost when it happened.....and I have hit 55-56 psi before, so I am sure after 44,000 tuned miles my stock bottom side boot had enough of my abuse.
post #9 of 31 (permalink) Old 09-01-2010, 01:48 AM
After they go BAM will the truck still run or are you dead in the water?
Is this something that can be fixed on the side of the road, if you have a set of boots with you?
post #10 of 31 (permalink) Old 09-01-2010, 03:51 AM
Spartan Diesel Tech
It will run, but you have no boost, your EGT's are through the roof, and the truck looks like it is on fire because there is so much black smoke pouring out of the exhaust.
Yes, it is something you can do on the side of the road. As long as you keep tools and boots in your truck, you will be good to go.
Where Can I find some good turbo boots? strawboss Diesel Conversion 2 05-28-2009 04:39 PM
Blowing boots after turbo cleaning toddsnorthriver 2003-2007 6.0L Power Stroke 25 03-05-2009 01:40 AM
Turbo boots 2tonePSD 1994-2003 7.3L Power Stroke 11 10-15-2007 03:41 PM
ipr and turbo boots marckluever Supporting Vendors Forum 1 07-06-2007 05:11 PM
Where can I order turbo boots? Southern4x4 1994-2003 7.3L Power Stroke 1 05-02-2007 04:26 PM
