DPF Back exhaust for Cab & Chassis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 5 replies and been viewed 1605 times.
post #1 of 6 (permalink) Old 09-01-2010, 01:52 AM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
Anyone put one on a cab & chassis??? If so what brand did you end up going with???
2003 F250 "Pulling Truck"
hhrecovery is offline
post #2 of 6 (permalink) Old 09-01-2010, 09:22 PM
Spartan Diesel Tech
08stroker250's Avatar
I don't know that there is a difference in the C&C pipes and the regular pipes. I could be wrong though. AFE or Flo-Pro would be best if your just going to delete the DPF and Cat.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 6 (permalink) Old 09-01-2010, 11:28 PM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
I need DPF back... there is a HUGE difference between a regular truck and a cab & chassis...
post #4 of 6 (permalink) Old 09-02-2010, 04:27 AM
Spartan Diesel Tech
Woops....my bad. I didn't read right lol
post #5 of 6 (permalink) Old 09-06-2010, 02:54 PM
BogginF350's Avatar
Aaron, we used a excursion cat back system and modded the hangers to get around the fuel tank.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #6 of 6 (permalink) Old 09-10-2010, 02:07 AM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
I talked to the guy in town that does flatbeds and he says 99-10 everything is identical and MBRP makes a tailpipe for 03-07 cab and chassis so I think that should work fine also...
Cab and Chassis Exhaust Kit brendonv Supporting Vendors Forum 0 10-03-2009 03:34 PM
Difference between cat back and turbo back exhaust thinbluelinetx 1994-2003 7.3L Power Stroke 3 08-10-2009 07:22 AM
cat back or turbo back exhaust DieselJr 2003-2007 6.0L Power Stroke 24 06-06-2009 09:45 PM
DPF-back exhaust indyfitter05 2008-2010 6.4L Power Stroke 21 01-05-2009 06:22 AM
DPF back exhaust IgotTwins 2008-2010 6.4L Engine Tuner Forum 11 03-24-2008 11:59 PM
