Big Reds Buildup - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Blk350on20s, this thread has received 5 replies and been viewed 1604 times.
post #1 of 6 (permalink) Old 09-29-2010, 12:52 AM Thread Starter
BLING BLING
Blk350on20s's Avatar
Send a message via AIM to Blk350on20s
Big Reds Buildup
Well some of you know that my truck cracked a piston. It was taken to the dealer where they had it for 2 months. They eventually denied my warranty and this is where the buildup began.
Obviously I needed a new piston so the essentials were bought from Feeny Ford in Grayling. I dealt with Chris who was awesome and has given me great prices on parts. So far from ford I have a Piston and ring kit, Rod bearings, head gaskets, Injector O ring kit, Exhaust manifold and up pipe gaskets, Intake Gaskets, Rocker box gaskets, and a new passenger side up pipe.
I didnít add to many performance parts to the build but a lot of preventative parts to keep the motor happy. I called Rudy up and ordered the Elite upgraded HPFP, ported rails, EGR delete with wastegate, Elites H11 headstuds, Elites CFM+ w/ adapter plate, and I got Rudys cold side IC pipe. I called up Mike Haller(97singlecab) for a set of his HPFP lines from the pump to the rails. Dan(sogrand) got a call for a billet oil cap. The fuel system needed to be addressed so I ordered some stuff from Jegs. I also got some bigger fittings for the supply and return on the HPFP. Ill be running a FASS 150/150 with a -8 line directly to the HPFP. Return side is all -6 with the fuel bowl and cooler deleted. Im using a 18Ē finned tranny cooler on the frame rail for a fuel cooler. I sent my oil pan, intake manifold, IC pipes, and valve covers powder coated red and my rocker boxes black. The Heads were machined and mildly ported by Gregs Cylinder Heads. The intake and exhaust manifolds were ported by a buddy of mine who runs a performance shop up here.
Heres some pictures of what done so far.
ID:	27185   Click image for larger version
ID:	27186   Click image for larger version
ID:	27187   Click image for larger version
Name:	motor out 022.jpg
ID:	27188   Click image for larger version
Name:	piston out 019.jpg
08 F350 4x4 CCSB 6.4, 6" on 37s and 22s, Spartan DD w/ 310/KEM 345, Elite HPFP, Ported rails, EGR delete w/ wastegate, studs, CFM +, Rudys IC pipe, BD BOV, FASS 150 w/ custom fuel system, S&B intake, Rudys downpipe and DOC/DPF delete, CCV mod, Zex nitrous, Suncoast Trans, 1 piece drive shaft, Recon and tint everywhere. Under Construction
Blk350on20s is offline
post #2 of 6 (permalink) Old 09-29-2010, 12:55 AM Thread Starter
BLING BLING
Some new parts
Name:	more truck 021.jpg
ID:	27190   Click image for larger version
Name:	more motor 027.jpg
ID:	27191   Click image for larger version
Name:	more motor 029.jpg
ID:	27192   Click image for larger version
Name:	more motor 030.jpg
ID:	27193   Click image for larger version
Name:	more motor 024.jpg
post #3 of 6 (permalink) Old 09-29-2010, 01:02 AM Thread Starter
BLING BLING
Starting to build
Name:	heads on 016.jpg
ID:	27195   Click image for larger version
Name:	heads on 018.jpg
ID:	27196   Click image for larger version
Name:	heads on 020.jpg
ID:	27197   Click image for larger version
Name:	heads on 022.jpg
ID:	27198   Click image for larger version
Name:	heads on 025.jpg
post #4 of 6 (permalink) Old 09-29-2010, 01:10 AM Thread Starter
BLING BLING
More build. studs torqued, motor in, trans bolted back up. The rocker boxes are torqued down as well as the intake manifold and CFM. Got the exhaust manifolds painted with 2000 deg. paint and torqued on. Valve covers are loosely bolted on. Couldnt get the rocker assembly in due to the tech from ford not putting any of my stuff in order so I had to order new push rods. Rudys shipped them out last Friday and I got them this week. Installing the rocker assembly tomorrow. Also got my fuel cooler in. Thing is huge. 18" long and about a 24oz can in diameter.
Name:	more motor 016.jpg
ID:	27200   Click image for larger version
Name:	more motor 017.jpg
ID:	27201   Click image for larger version
Name:	fuel cooler 002.jpg
ID:	27202   Click image for larger version
Name:	fuel cooler 003.jpg
ID:	27203   Click image for larger version
Name:	fuel cooler 005.jpg
post #5 of 6 (permalink) Old 09-29-2010, 01:14 AM
Banned
Looks like your on the road to recovery. Thanks for the pictures.
wastedwagesracing is offline
post #6 of 6 (permalink) Old 09-30-2010, 05:52 PM
Great post...keep us up to date. I bet she is going to be a monster once she is done. How much money is the build going to cost you roughly?
2008 HD F250 CCSB, Spartan, AFE downpipe back exhaust
joe22790 is offline
400 HP Buildup? woodsman 1994-2003 7.3L Power Stroke 14 10-03-2009 01:46 PM
hotshot fantasy buildup muscletruck7379 Medium and Heavy Duty 9 09-10-2009 02:15 AM
direction on motor buildup (horse power) CrashFireRescue 5.9L Cummins (2003-2007.5) 7 06-12-2009 01:16 AM
Arroyo gets fourth win as Reds sweep Nationals RSS Feeder The Parking Lot 0 04-27-2006 07:00 AM
6.2l buildup in Diesel Power Mag strokin 6.2L Diesel Engine 6 12-27-2005 10:03 PM
