Turbo Diesel Lifesaver - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08smoker08, this thread has received 6 replies and been viewed 1533 times.
post #1 of 7 (permalink) Old 10-06-2010, 04:23 PM Thread Starter
08smoker08's Avatar
Has anyone put one of these on our trucks? If so how do you like it?
I am new to diesel and turbochargers how do you get your turbo hot enough that it hurts it when turning off the engine? Does just normal driving do this?
Any thoughts on the letting the chip turn off your truck? If it lets the truck idle longer than 10-15 mins then you get other issues correct?
08smoker08 is offline
post #2 of 7 (permalink) Old 10-07-2010, 01:37 AM
FukeneH
dirty mech's Avatar
are you pulling heavy loads?
dirty mech is offline
post #3 of 7 (permalink) Old 10-07-2010, 09:40 AM Thread Starter
08smoker08's Avatar
nope not really. Hauling stuff from lowes that fits in the bed but even then not really that heavy. I imagine i do not need this but was just curious how easy it is to get the temps where you would need one.
post #4 of 7 (permalink) Old 10-12-2010, 01:31 AM
pyro2nite's Avatar
If you pull heavy loads then a 3 min idle before shutting down will keep the turbo healthy. Normal driving will not require a cool down.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #5 of 7 (permalink) Old 10-15-2010, 12:43 AM
Far Rider
mowtown's Avatar
I love mine, use it every day all the time. Here's an example..... It's 95 out side and you need to run into the grocery store to grab something on your way home but you dont want to turn the A/C off because you will want your truck nice and cool when you come out, well with the turbo lifesaver you can set it for how long you want it to run,turn the key to the off positon,remove it and walk away, now you can go inside do what you gotta do and come back out to nice cool truck. Also if someone try's to steal it while it's running with the key out it will shut off and the wont be able to restart it since you have the key.
mowtown is offline
post #6 of 7 (permalink) Old 10-15-2010, 01:39 AM
GUTTS's Avatar
is your turbo saver part of your alarm system or just a turbo saver and what kind is it
GUTTS is offline
post #7 of 7 (permalink) Old 10-15-2010, 01:47 PM
Roach
Roach's Avatar
Mine is part of the alarm system. It is an Audiovox Prestige, 2-way remote start. When I stop, I apply the emergency brake, and the truck will idle for 3 minutes. I can activate the the remote start with the engine running, and turn off the key, exit the truck, lock the doors, and the truck will idle for 20 minutes. Usually I am back in it before the 20 minutes. We travel with 2 small dogs, and if it is hot, we let the truck a/c keep them cool.
2008 F-350 Lariat Dually, 4X4, Long Bed, Sirus Radio, Prestige Remote Start/Turbo Timer, Retrax Bed Cover, Power Tailgate Lock, Pillar Guages, Pyro, Boost, Trans Temp., chrome door handles, chrome fuel filler door.
Roach is offline
Considering 1st Diesel - 98 Chevy 3500 Bucket Van - 6.5 Turbo Diesel landlord Introductions 6 05-01-2008 12:10 AM
89 7.3 non turbo diesel kingkuality 7.3L and 6.9 IDI (Pre 1994) 4 01-09-2008 03:27 PM
Diesel turbo lifesaver 94-04 double-s-diesel Whats Been Sold 0 06-20-2007 05:03 PM
Anyone use the Diesel Turbo Lifesaver? 75867586 2003-2007 6.0L Power Stroke 2 10-07-2006 04:20 PM
Turbo lifesaver n2diesel General Ford Truck and Excursion 11 04-25-2006 01:43 PM
