spartan tuner and exhaust install writeup - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99_stroker, this thread has received 16 replies and been viewed 13524 times.
post #1 of 17 (permalink) Old 10-13-2010, 05:44 PM Thread Starter
99_stroker's Avatar
Has anyone done one of theese. I honestly dont have the first clue what to do when my spartan comes ive been reading up on it but the water is still very muddy the exhaust dosent seem to bad though. When i get my spartan do i just plug it in and the tunes are all there or do i hafta download a bunch of crap im not on the geek squad when it comes to computers by any means
Grein,
1999, ford f-250 superduty cc, lb, diy intake, dp tuner, 3 gauge pillar, tint all the way around, gto smoked heads and tails, uniden cb, recon smoked cab lights, recon running lights, recon third brake light
99_stroker is offline
post #2 of 17 (permalink) Old 10-13-2010, 06:34 PM
2008 F350 Murdered out
alex8888's Avatar
Extremly simple all you do is plug it into your obd2 port and then your gonna navigate to tuning and once you choose your tune that you wish to load lets just say the 250 tune, so the dd will then give you some commands and then it will begin to save your stock tune, and will load the 250 should take 30-45 mins for the first time, and while the dd is doing that your gonna be underneath working on the exhaust, easy as pie. Give me a call if you got more questions. 256-684-4545
2008 f350 king ranch Spartanized with all tunes even the 345!!!! full 4" downpipe back with 7" tip, JL500/1v2 ,300/1v4, 2 JL 10w1v2 subs, JL door speakers c2 570x and pioneer tweeters ts110, pioneer avic z110 BT, Top gun front bumper replacement, ranchhand back bumper, -3% tint side 4, back 5%, front 30%, nathan air chime p3 train horn, all recon accesories. 2.5 lift, 35" nitto trail mt, 20"xd series wheels
alex8888 is offline
post #3 of 17 (permalink) Old 10-13-2010, 06:35 PM
Your best bet is to plug in the Dash Daq to your computer, use the CD to learn it in and out and register your vehicle and VIN with Spartan. You will need to contact them for a USER name and temp password to set up the account unless the distributor set it with the unit. This is necessary to get you VIN loaded so you can reflash your PCM with the stock tune if something happens to your dash Daq. It is also necessary to unlock the tunes above 250 DPF delete, and EGR delete tunes.
However you can plug in the Dash Daq to your OBDII port for quick start and follow the screen prompts. To load the tune you select that option and load tunes. Again screen prompts are your friend and when you upload the stock tune to the DashDaq for the first time it says 32 minutes mine took almost 90 minutes, so heed the disclaimer to charge your truck while tuning. Subsequent times are significantly shorter, it only takes 10 minutes to go between 210 tow and 250.
The exhaust is the worst part and depending on your kit, probably came with no directions.
The one important note is that the DPF/DOC can be removed by unbolting the hangers rather than trying to slip the hanger hooks out the bushings. That is of course assuming you purchased a DPF/DOC delete pipe, if you purchased the DPF only you will have to unbolt it from the DOC and that may take a bit of penetrating oil. The one piece DPF/DOC pipe from Rudy's utilizes no hangers.
Remember that the DPF is a heavy monster!!!
Good luck
Remember to tune your truck prior to removing DPF componenets!
Jeremy Payne
2010 Heartland Sundance 3300RLB
2009 XLT F150 Super Crew Short Box 4x4 5.4L[
2008 Lariat F350 Crew Cab Long Box 4x4 6.4L
-Spartan tuned, S&B Cold Air Intake, Cold side Intercooler pipe, 4" Down pipe, Powerstroker67 DPF/CAT delete, MBRP 4" Black Series w/5" tip.
2005 Yamaha R6
1971 M35A2 AM General W/O Winch
Bighurt is offline
post #4 of 17 (permalink) Old 10-13-2010, 10:29 PM Thread Starter
99_stroker's Avatar
thanks for the quick replies that helps clear the water alot. I should have said what exactly i have ordered. It all came from rudy spartan with the 275 and 310 tunes and a full five inch exhaust everything deleted. From what i understand in order for me to use the 310 or 275 ect. i have to register with spartan is this correct? thanks again for all the help
Grein,
post #5 of 17 (permalink) Old 10-13-2010, 10:56 PM Thread Starter
99_stroker's Avatar
ohh and another quick question. I have been reading a little on spartan's website and i stumbled acrosed a thread that said the shifting when tuned was absolutely terrible. Is this true at all? I plan to run the 310 tune daily but i am hardly ever on the truck to hard
Grein,
post #6 of 17 (permalink) Old 10-13-2010, 11:52 PM
Spartan Diesel Tech
08stroker250's Avatar
Some people just don't like or understand the need for added line pressure on a stock transmission with a 300+ horsepower tune meant for racing. I would recommend looking in to the 300 tune when it is available. Unless they just haven't told me yet, the 300 isn't quite available but will be VERY soon.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #7 of 17 (permalink) Old 10-14-2010, 12:46 AM Thread Starter
99_stroker's Avatar
ok thanks. im still a little confused when i plug in my tuner are the tunes on there or do i put them on there somehow?
Grein,
post #8 of 17 (permalink) Old 10-14-2010, 01:14 AM
5" from where? As far as I know Rudy's via powerstroker67 only offers a 4" DOC/DPF, but I could be wrong. I'm pretty sure a 5" downpipe is impossible without cab modification.
To answer your question you need to register to unlock higher tunes if not pre-unlocked as well as recover your stock tune in the event of DashDaq failure.
At least that was what I was told, things always change.
Jeremy Payne
2005 Yamaha R6
Bighurt is offline
post #9 of 17 (permalink) Old 10-14-2010, 01:36 AM Thread Starter
99_stroker's Avatar
sorry about that its the flo-pro 5 inch downpipe back exhaust. I didnt see the need to get a downpipe yet
Grein,
post #10 of 17 (permalink) Old 10-14-2010, 04:05 AM
I liked it!!!
Jeremy Payne
2005 Yamaha R6
Bighurt is offline
Spartan Tuner 08-09 6.4 Dual Tandem Ford Parts 7 03-14-2010 11:38 PM
Spartan tuner with full delete and exhaust CDriver Whats Been Sold 8 12-09-2009 02:04 AM
Spartan Tuner DAL-TEX Ford Parts 0 10-20-2009 09:32 PM
Reflash before install Spartan alex8888 2008-2010 6.4L Engine Tuner Forum 4 05-03-2009 05:31 PM
volant 304SS turbo back exhaust install/writeup and EGR uppipe weld barry1me 2003-2007 6.0L Power Stroke 18 08-20-2007 08:56 PM
