Spartan 125 dpf tune idle up - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Megaman, this thread has received 6 replies and been viewed 1639 times.
post #1 of 7 (permalink) Old 10-16-2010, 06:09 AM Thread Starter
Megaman's Avatar
If I drive my truck for a few miles and then stop and put it in park and the idle will go up to 1100 after a few min. Is this normal?
Thanks
BTW the 125 dpf tune runs very strong. This is the way ford should have made it.
08 F350 Lariat, Job 3, 00 F450 Flat bed.
Icon 2.5 lift with trac bar
Spartan 210 and DPF delete
The avatar picture is what I do on the side for a few pro mx riders
Megaman is offline
post #2 of 7 (permalink) Old 10-16-2010, 01:50 PM
Thanks
Yes, idling a diesel at low idle does not allow the fuel to burn efficiently as a result a condition called "Wet Stacking" will occur. Sulfation issues also begin to present. As a result the truck is designed to high idle after a few minutes, some states don't allow diesels to idle longer than a given amount of time, and the truck will shut down.
It's normal, and necessary in the winter, at least here.
Jeremy Payne
2010 Heartland Sundance 3300RLB
2009 XLT F150 Super Crew Short Box 4x4 5.4L[
2008 Lariat F350 Crew Cab Long Box 4x4 6.4L
-Spartan tuned, S&B Cold Air Intake, Cold side Intercooler pipe, 4" Down pipe, Powerstroker67 DPF/CAT delete, MBRP 4" Black Series w/5" tip.
2005 Yamaha R6
1971 M35A2 AM General W/O Winch
Bighurt is offline
post #3 of 7 (permalink) Old 10-16-2010, 05:15 PM Thread Starter
Megaman's Avatar
Thanks
Megaman is offline
post #4 of 7 (permalink) Old 10-18-2010, 05:50 PM
Spartan Diesel Tech
08stroker250's Avatar
The truck may be in regeneration when this is occurring. Our DPF on tunes still allow the idle up regeneration that use to happen with stock trucks.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #5 of 7 (permalink) Old 10-19-2010, 04:05 AM Thread Starter
Megaman's Avatar
One more quick question. Can I use the tuner on my other truck if I first return my truck to stock?
Megaman is offline
post #6 of 7 (permalink) Old 10-19-2010, 05:24 AM
You can only use the tunes for one VIN, you can get another license for $650 I think and use the same DD for both.
I think you can still use the DD for diagnostics on another vehicle but I'm not sure.
Jeremy Payne
2005 Yamaha R6
Bighurt is offline
post #7 of 7 (permalink) Old 10-20-2010, 01:29 AM
Spartan Diesel Tech
A new license for it to work on another truck is $699. Doing this also gets rid of the "strategy flash" option.
Spartan 150 DPF On Tune? rmkhauler 2008-2010 6.4L Engine Tuner Forum 1 01-19-2010 03:15 AM
Which tune from spartan???? 210,250,275 taz1 2008-2010 6.4L Engine Tuner Forum 8 10-23-2009 03:53 PM
Spartan 310 tune [email protected] 2008-2010 6.4L Engine Tuner Forum 114 05-05-2009 01:00 AM
Spartan 275 Tune gunford 2008-2010 6.4L Engine Tuner Forum 62 01-30-2009 02:28 AM
MPG Spartan tune 210 mgm2 2008-2010 6.4L Engine Tuner Forum 10 01-26-2009 05:32 PM
