300 Tune Info - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08stroker250, this thread has received 21 replies and been viewed 4422 times.
post #1 of 22 (permalink) Old 10-21-2010, 09:51 PM Thread Starter
Spartan Diesel Tech
08stroker250's Avatar
Exclamation 300 Tune Info
This is for those of you with Job 2 trucks and newer with Level 3 Tier licenses (already have the 275, 310, and EGR delete tunes). If you want the 300 tune you must do the following....
Send an email to Mick at [email protected] with your Name, DashDAQ SERIAL #, and who you purchased the tuner from. IF you did not purchase the tuner through Spartan, you must fax us (or email us) a signed "Off-Road Tuning Disclaimer". The fax number is 828-692-9968.
NOTE - Let Mick know in your email that you are wanting to update the tuner and get the 300 tune. This way he will know what the email is regarding.
Just a heads up. When you do this, your tuner will also be getting E-Motion's latest software for the DashDAQ. This means that all of your old tunes will no longer work, BUT you can get Mick to remake you an old tune that you have as an .ENC file at no charge. ALSO, if your tuner is strategy flash you will need to send Mick your original stock file. Make sure you do this because it will no longer work with the update.
Job 1 files are still in testing and should be available soon!
Thanks,
[email protected]Spartan
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #2 of 22 (permalink) Old 10-21-2010, 10:30 PM
What are the differences between the 300 and 310 tune? Different shifting? I would think it's not just a power difference being that close to an existing tune.
cartmanea is offline
post #3 of 22 (permalink) Old 10-22-2010, 02:02 AM Thread Starter
Spartan Diesel Tech
Smoother shifting and a much more tame throttle. It is the "test tune" that I started discussion about 2 months ago or so.
post #4 of 22 (permalink) Old 10-23-2010, 12:09 AM
I would like to know what is involved in "updating" or how to go about gettin this tune. Would love to have that smoother shifting tune. How much smoke is it compared to the 250?
08 Job 3 250 4 door, 6 inch lift, AFE straight piped, AFE drop in filter and Spartan tuned. 91 Procharged mustang
beaslyb is offline
post #5 of 22 (permalink) Old 10-23-2010, 01:01 PM
My daily driver is the 250 (all around awesome tune). I also tow my 13,000lb 5th on this setting as well - no issues.
Hoping the 300 becomes the new all around tune.
2008 F450 - Pearl Blue with Tan - 4.30 (Job 3)
Spartan 310hp w/TCM, Airaid Drop In Filter, 5" MBRP w/ 6" Tip, 2" level kit, Firestone Air bags in the rear, Bilstein's all around
2010 Open Range 429bhs 5th
http://good-times.webshots.com/album/565591458baIstp
Black06 is offline
post #6 of 22 (permalink) Old 10-23-2010, 01:35 PM
Ford 6.4 it's just cooler
trapit's Avatar
Jeff your avatar pic...classic
Paul Alewine
2008 F-250 King Ranch AFE Stage II MBRP Duals and Spartan 310 Tuned
2" BDS Lift on 35" Toyo M/T's
Singles Club #74
American Club #13
trapit is offline
post #7 of 22 (permalink) Old 10-24-2010, 10:55 PM Thread Starter
Spartan Diesel Tech
Email Mick, he will walk you through everything that has to happen. As far as smoke output, it is smokier. It is a bigger tune. The smoke can easill be controlled with the right foot though.
Zach is my hero!
post #8 of 22 (permalink) Old 10-25-2010, 02:08 AM
"Not at the table carlos"....
slowmans is offline
post #9 of 22 (permalink) Old 10-25-2010, 05:06 AM
BigPSD's Avatar
Is this tune as streetable as the 275? Other then the extra 25hp how is this tune on the tranny?
BigPSD is offline
post #10 of 22 (permalink) Old 10-25-2010, 05:52 PM
trapit's Avatar
I was about to put the same thing
Paul Alewine
Singles Club #74
American Club #13
trapit is offline
info for a tune up..... BOBCAT_JON 1994-2003 7.3L Power Stroke 7 03-30-2010 02:45 AM
SCT Custom tune info Hollywood 2008-2010 6.4L Engine Tuner Forum 8 02-12-2009 09:59 PM
ELITE insanity tune vs IDP extreme tune flaresniper 2003-2007 6.0 Tuner Forum 21 11-12-2006 05:56 PM
Build an SCT tune with datalogging info? nummit 2003-2007 6.0 Tuner Forum 6 07-01-2006 03:42 AM
Superchips Perf. Tune feels slower than Econ tune.. crappace 2003-2007 6.0 Tuner Forum 4 05-10-2006 09:59 PM
