Regen without dpf - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thartman, this thread has received 1 replies and been viewed 1500 times.
post #1 of 2 (permalink) Old 10-31-2010, 10:11 PM Thread Starter
Regen without dpf
The other day I reprogrammed my truck and forgot to turn regen off. Soon as it came on Iturned the truck off. It runs fine now should I have any problems from this.
thartman is offline
post #2 of 2 (permalink) Old 11-01-2010, 01:57 AM
pyro2nite's Avatar
Should not be a problem. Usually with the DPF removed it will go into a permanent regen.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
The Following User Says Thank You to pyro2nite For this addition to TDG:
thartman (11-02-2010)
How often do you regen? Bad Idea Baja 2008-2010 6.4L Power Stroke 20 12-29-2008 12:38 AM
regen ? silverpeteok Duramax 07.5-2010 (LMM) 4 03-27-2008 11:31 AM
No Regen yet ryanandkitty Duramax 07.5-2010 (LMM) 21 02-04-2008 06:01 PM
Regen or not to Regen? fmfreight 2008-2010 6.4L Power Stroke 3 01-20-2008 03:53 PM
Regen? Jays7.3 2008-2010 6.4L Power Stroke 2 10-18-2007 01:20 AM
