Question about Removing Factory Tail Pipe - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Truckmaniac, this thread has received 7 replies and been viewed 1717 times.
post #1 of 8 (permalink) Old 12-10-2010, 04:26 PM Thread Starter
I'm running the DPF/CAT delete on my 2010 F250 Shortbed and am starting to Hate the look of the funky exhaust tips. I'd like to remove the stock tail pipe/exhaust resonator/tip assembly and replace with an aftermarket unit.
Can the factory tail pipe assembly be removed without cutting it and/or without the use of a lift? I want to save it for warranty work or the next purchaser.
Would you recommend having a local muffler shop build the new tail pipe or purchasing an aftermarket unit? It appears that most of the aftermarket pipes have "vents" on or near the tip and since I don't regenerate, I don't need this feature or like the looks of it.
Since I trade trucks every 1 to 2 years, do I need to spend the extra $$$ for stainless steel or just go with aluminized steel? I live in West Texas where it is dry.
Truckmaniac is offline
post #2 of 8 (permalink) Old 12-10-2010, 09:51 PM
Spartan Diesel Tech
08stroker250's Avatar
Mine was cut. I think you may be able to get it off without cutting, but I think most people drop the passenger rear shock to make it easier, which isn't to bad.
I would go with an aluminized system since you probably won't have to many run ins with salted roads. I think Flo-Pro makes a DPF back kit without vents. AFE may as well. I think there is one DPF back unit available that has the vents under the truck and not at the tip. Can't remember if it's Banks or Gibson. I would just do some searching and vendor contacting!
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 8 (permalink) Old 12-10-2010, 09:52 PM
Spartan Diesel Tech
The Following User Says Thank You to 08stroker250 For this addition to TDG:
Truckmaniac (12-11-2010)
post #4 of 8 (permalink) Old 12-11-2010, 01:11 AM
FukeneH
dirty mech's Avatar
i removed mine with a floor jack and removing the rear pass tire,also removed bottom bolt on shock and swung shock up. had it off the truck in one piece in 15mins
dirty mech is offline
The Following User Says Thank You to dirty mech For this addition to TDG:
post #5 of 8 (permalink) Old 12-12-2010, 05:07 AM
Spartan Diesel Tech
Ughhhh!!! I hate double posting!
Has anyone else noticed this site being RRRREEEEEAAAAALLLLLLLLYYYYYYYY slow lately? The reason I say this site is because I frequent about 5 other forums...nightly (I know, I'm a loser).....and none of them are as slow as TDG.
post #6 of 8 (permalink) Old 12-12-2010, 05:57 AM
bannon_500's Avatar
Put a floor jack under the receiver hitch on the back of the truck, and jack it up until your suspension is maxed out right before your rear tires come off the ground and you should have enough room between the truck and the axle to snake the tail pipe through there without cuttin it
Jason
Purdue Diesel Club-President
Smokers Club #13
2003 F-250 Reg. cab, long bed, FX4, 6.0 Powerstroke, 6-speed manual
585 HP 1,251 FtLb
SCT tuned by Innovative, 225cc Swamps injectors, S363 Fleece Performance turbo with a billet wheel, Dieselsite billet high volume HPOP, Snow Stage 2 water/meth, ARP Headstuds, RCD EGR delete, Liberator O-ringed heads, Black onyx headgaskets, ITP regulated return, SouthBend 3600 Dual Disc clutch, Airdog 100, CFM intake manifold, Dfuser coolant filter kit, 4" exhaust into 7" stack, AEM intake, Autometer Ultralite boost, pyro, fuel pressure, and air pressure gauge for my Hornblasters.com train horn kit,
Superlift leveling kit w/ 2" lift blocks in the back, 20x10 XD Diesels, 35x13.50x20 Cooper STTs
Kenwood DVD player, 1000 watt Sony Xplod amp with a 12" Bazooka tube and 10" MTX sub
bannon_500 is offline
post #7 of 8 (permalink) Old 12-12-2010, 03:25 PM Thread Starter
You're right, this site has been super-slow for a few days now.
How can you be a loser with a good looking kid like that?
That is your kid in your Avatar?
post #8 of 8 (permalink) Old 12-12-2010, 06:45 PM
FukeneH
dirty mech's Avatar
HAHA that is some funny shait right there
Help!! Oil out the tail pipe kingbpg 1994-2003 7.3L Power Stroke 9 04-05-2009 08:47 PM
Tail Pipe... Cummins2001 5.9L Cummins (2003-2007.5) 4 07-29-2007 06:22 AM
Removing Flex Pipe on Up-Pipe and Y Pipe hhrecovery 2003-2007 6.0L Power Stroke 27 11-28-2006 10:36 PM
7.3 99-03 stock exhaust complete from down pipe to tail pipe Bella PSD Whats Been Sold 2 03-21-2006 11:21 PM
