S&B intake. Any HP gains? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Megaman, this thread has received 4 replies and been viewed 2646 times.
post #1 of 5 (permalink) Old 12-27-2010, 01:53 AM Thread Starter
Megaman's Avatar
I have a 6.4 with a Spartan 210 tune. I would like to upgrade the intake system. So my question is simple. Does a intake system make HP over stock.
08 F350 Lariat, Job 3, 00 F450 Flat bed.
Icon 2.5 lift with trac bar
Spartan 210 and DPF delete
The avatar picture is what I do on the side for a few pro mx riders
Megaman is offline
post #2 of 5 (permalink) Old 12-27-2010, 06:10 PM
Megaman I did the S&B intake on my truck a few months ago but did a BD power intercooler pipe at the same time i usually run my truck on the 210 or 250 tune as far as hp numbers go I dont know if I gained anything as I've never had the truck on a dyno I did however notice a drop in EGT's about 100 degrees or so and a little bit better spool up on the turbos, hope this helps
squamishf350 is offline
post #3 of 5 (permalink) Old 12-27-2010, 07:21 PM
Spartan Diesel Tech
08stroker250's Avatar
It's going to give you a few horsepower increase simply from the increase in air flow and efficiency. Nothing major though.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #4 of 5 (permalink) Old 12-28-2010, 10:43 PM Thread Starter
Megaman's Avatar
Thanks guys.
So would you guys still buy one again if you had to do it all over again?
Megaman is offline
post #5 of 5 (permalink) Old 12-29-2010, 02:50 AM
Spartan Diesel Tech
I don't have one. I run an AFE Stage II PG-7. It is necessary above a 200-210 tune in my opinion.
Air dog II fuel system Any gains??? PiRiPi 2003-2007 6.0L Power Stroke 3 08-19-2009 11:33 PM
MPG Gains from 250 to 275 Tune surveyor13 2008-2010 6.4L Engine Tuner Forum 4 01-27-2009 04:15 PM
chip/tuner for milage gains joeseppy LBZ & LLY Tuner Forum 17 12-30-2007 01:12 AM
Recommendations on HP gains on 91 cumminspride 7.3L and 6.9 IDI (Pre 1994) 2 04-04-2007 01:51 PM
BHAF gains airgrabber70 5.9L Cummins 12 Valve (1994-1998.5) 9 02-04-2007 12:41 AM
