Spartan Tuner ??? before buying - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by snopro_69, this thread has received 26 replies and been viewed 8897 times.
post #1 of 27 (permalink) Old 01-08-2011, 11:50 PM Thread Starter
hey i just bought a 6.4 2008 an been doin alot of research on tuners and liking all the info on the spartan... just wonderin if it reads EGT's pre and post turbos or where the stock pyrometers are on the engines or if any?? any info would be great!!! thanks all
snopro_69 is offline
post #2 of 27 (permalink) Old 01-09-2011, 01:29 AM
It reads pre turbo or one of the 3 in the exsaust but you want the pre turbo.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 27 (permalink) Old 01-10-2011, 06:14 PM
Spartan Diesel Tech
08stroker250's Avatar
You can monitor both. 1 pre-turbo and 3 post-turbo. You could even monitor them all at the same time if you wanted!
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #4 of 27 (permalink) Old 01-10-2011, 08:11 PM
Spartan is a good product. You won't be disappointed. Coming up 40,000 miles and 35,000 of them tuned - without issue. I tow a 14,000lb 5th on the 210hp mode, and run daily on the 300hp tune (fast and smooth).
Do it all over again - yes I would.
2008 F450 - Pearl Blue with Tan - 4.30 (Job 3)
Spartan 310hp w/TCM, Airaid Drop In Filter, 5" MBRP w/ 6" Tip, 2" level kit, Firestone Air bags in the rear, Bilstein's all around
2010 Open Range 429bhs 5th
http://good-times.webshots.com/album/565591458baIstp
Black06 is offline
post #5 of 27 (permalink) Old 01-12-2011, 04:08 AM Thread Starter
thanks guys! sounds awesome.... im sold on gettin one... few more weeks of savin a lil money and shes GO TIME!
post #6 of 27 (permalink) Old 01-17-2011, 11:31 PM
GMC2500HD's Avatar
Look at H&S before you buy a spartan... You will be surprised what you get from H&S...
GMC2500HD is offline
post #7 of 27 (permalink) Old 01-22-2011, 02:13 AM Thread Starter
does the spartan have the option of running turbo back exhaust with no sensors put back in the pipe?? can you just turn them off wen running the DPF tunes?
post #8 of 27 (permalink) Old 01-22-2011, 02:43 AM
Spartan Diesel Tech
No sensors are needed once you delete the DPF.
post #9 of 27 (permalink) Old 01-23-2011, 11:59 AM
deebarjay's Avatar
sensors
need to get something straight in my mind....did spartan at one time need the sensors and now you are the same as H&S ??? and dont. ...seem to remember guys breaking sensors and having to replace them on the delete...fact is i also remember bungs welded onto the delete replace pipes.
2008 SILVER XLT extended cab,8ft.bed,3.55, 6.4 auto,100 gallon Delta sliptank,goosenek hitch,timbrens,torklift tiedowns.
deebarjay is offline
post #10 of 27 (permalink) Old 01-23-2011, 02:50 PM
Did things change and I was asleep?
Truckmaniac is offline
Spartan Tuner 08-09 6.4 Dual Tandem Ford Parts 7 03-14-2010 11:38 PM
Spartan Tuner DAL-TEX Ford Parts 0 10-20-2009 09:32 PM
Buying a Spartan cbrown 2008-2010 6.4L Engine Tuner Forum 3 06-16-2009 11:00 PM
Buying a used Spartan... LovinPSDs 2008-2010 6.4L Engine Tuner Forum 12 02-05-2009 04:24 AM
Upgrades When Buying A Tuner circle5 1994-2003 7.3L Chips & Tuners Forum 25 11-18-2006 06:33 PM
