Thefit problem with mounting location? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Loghome Couple, this thread has received 8 replies and been viewed 1780 times.
post #1 of 9 (permalink) Old 02-13-2011, 05:03 PM Thread Starter
Loghome Couple's Avatar
Has anyone had an issue when your tuner is mounted above the vent on the drivers side, or on the A-pillar for that matter, of being broke into and getting your tuner swiped? Since it is in plain view I'm wondering if the low lifes might think it is a GPS unit and rip it off for a quick buck?
Loghome Couple is offline
post #2 of 9 (permalink) Old 02-14-2011, 06:34 AM
ipkyss's Avatar
my dashdaq is mounted above my rear view mirror and my gps is in the top left corner of the window. 8" tint strip on the top of the windshield and 15% tint on the door windows. You can't see mine in direct sunlight. I would be afraid to park my truck anywhere with the a pillar mounts. I can't stomach the fact that when the idiot that robs it, figures out its not a gps, He will just trash it...
New Ride 08 F-250 CC SB FX-4 6.4 auto loaded job 1, Spartan 310,RCD 485,525, Erics Xstreet,KEM250 DPF delete,downpipe, intercooler pipe, 4" mbrp, timbrens
04 F-350 6.0,auto,SC,SB, 8ft Fisher X-Blade, Hideaway Strobes, XM Radio,Alpine Head unit, X-codes, Edge Mini spring pack, Edge adjustable track bar, 315/75/16 Toyo A/t,Prodigy brake controler,MBRP 3.5" downpipe,5"stacks, powermaxx turbo, Xrace tuned
Old truck-3/27/03 build F-350,CC,SB,DRW 6.0, Auto, Black on black, Blacked out bumpers/ grill, Moon roof, fifth wheel.
old sick, 1/7/03 build
2003 F-350,SC,SB,6.0, 4" lift 37 MT/R
http://community.webshots.com/user/traxx400-date
http://s601.photobucket.com/albums/t...0Ford%20F-250/
ipkyss is offline
post #3 of 9 (permalink) Old 02-14-2011, 09:33 AM Thread Starter
That is what I was thinking too. Thanks for verifying I'm not the only one thinking this.
post #4 of 9 (permalink) Old 02-14-2011, 12:26 PM
Boaz's Avatar
It is farily simple to break into these trucks through the door handle. If you park it anywhere and the robbers have the tim ethey will steal anything in the truck. Had both my GPS and tuner stole from in front of a restaurant. I suspect they were in and outof the truck in less than a minute. I have changed the lock on the door and remove all visible material from the truck if they want it they can get it. I will not risk losing another tuner in this manner or a GPS. Take caution with your belongings.
2008 Job 1 F250 CC 4X4 SB Stock
Boaz is offline
post #5 of 9 (permalink) Old 02-14-2011, 02:24 PM
How did you mount the DD above your rear view mirror? I like that idea better than the other mounting options I have seen.
keving is offline
post #6 of 9 (permalink) Old 02-16-2011, 01:38 AM
Auto's are for pansies
Slick Willie's Avatar
There's a bunch of people that have had their DD stolen with it in view from a window. Most had other stuff stolen too, but if the DD is in view, IMO, you're asking for it.
As for mounting options, there are threads on many different mounting options. I've got mine mounted where most of y'all have a 4x4 switch to the left of the AC. A quick search will show you a few more, but here are some:
https://www.thedieselgarage.com/forum...unting+options
Slick Willie is offline
post #7 of 9 (permalink) Old 02-16-2011, 03:52 AM
ipkyss's Avatar
Factory mount and wire. The mount holds it in place and it rests on the top of the mirror. I might have taken the mount apart and put it back together a little different. Don't quite remember now. It did take some time to get it in just the right spot. Mount even stuck good to the tint.
ipkyss is offline
post #8 of 9 (permalink) Old 02-16-2011, 09:25 AM Thread Starter
Well done, looks great! When you say factory mount which factory are you referring to? Also, how easy is it to remove from there if you want to hide it if you are parked in some seedy area?
post #9 of 9 (permalink) Old 02-16-2011, 04:43 PM
ipkyss's Avatar
Its just the suction cup mount that came with it. All you have to do is pull it out of the clip and un clip the wire. It takes a few minutes to get it back in, but I'm fairly anal when it comes to stuff like that. I like it on just the right angle to the seat.
Like I said before, I never remove the dashdaq or my gps. Even if you put your face up to the door window and look for them, you really can't see them. Unless you leave them on... I like it above the mirror. I drive big trucks for a living, so I am use to constantly watching the mirrors. That leaves the display constantly in sight.
ipkyss is offline
Theft problem with mounting location? Loghome Couple 2008-2010 6.4L Power Stroke 1 02-13-2011 12:14 PM
H2E and mounting kit pontiacross Whats Been Sold 6 03-27-2008 02:47 AM
H2E Mounting Kit genie144 Supporting Vendors Forum 2 03-26-2008 05:05 PM
H2e mounting? BigRed97 1994-2003 7.3L Power Stroke 11 11-16-2007 09:35 PM
CB Mounting TowRig General Ford Truck and Excursion 27 04-09-2007 03:07 AM
