2009 F550 4R100 Transmission Temp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by will7104, this thread has received 3 replies and been viewed 2224 times.
post #1 of 4 (permalink) Old 04-12-2011, 02:50 AM Thread Starter
I just purchased a 2009 F550 and installed a Transmission Temp gauge in the PP, what are the average temps I should be reading? This is a 4R100 Tranny ?
will7104 is offline
post #2 of 4 (permalink) Old 04-12-2011, 04:50 AM
Spartan Diesel Tech
08stroker250's Avatar
No. They haven't put a 4R100 behind a Power Stroke since 2003 (last of the 7.3's). 2003 6.0's up to 2010 6.4's have 5R110's, with the 6.0 5R having a little less than the 6.4 5R. The 2011 trucks have 6R140's.
Temps should average between 155-170 while daily driving, 170-185 while running the truck harder (light towing, hard runs through the gears unloaded). Heavy towing can get temps up in to the 210-230 degree range. Once you get in that 230 and higher range, the fluid is starting to cook itself.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 4 (permalink) Old 04-12-2011, 05:44 AM
hayjayhorses's Avatar
the trans temp should be taken at the cooler line coming out of the trans. That is were you will see how hot you torque converter is.
I don't know about the 5R110, but on the 4R100 the Pres. Port. is basically reading the case temp and the aluminum case acts like a heat sink for the engine.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #4 of 4 (permalink) Old 04-12-2011, 05:56 AM Thread Starter
2009 F550 5R100 trans temps
Thanks for the info. My 2005 F350 was running about 140 so I was concerned about the higher temps I was seeing in my 550. Arer there any suggestions to lower the temp? Or should I not be concerned about it?
will7104 is offline
Tags
ford 4r100
4R100 transmission problem tooty 1994-2003 7.3L Power Stroke 5 11-03-2010 03:56 AM
4R100 4x4 transmission w/BTS valve body JDH Whats Been Sold 0 01-11-2009 01:39 PM
2008-2009 superdutys with automatic transmission and manual tranfercase stroker7.3L444 2008-2010 6.4L Power Stroke 12 01-02-2009 06:02 PM
Transmission Temp Sender rvpilot 2003-2007 6.0L Power Stroke 3 09-25-2007 10:41 PM
Looking for advice on the best transmission, 4R100 99BoggerTJ 1994-2003 7.3L Power Stroke 10 12-31-2006 05:20 PM
