getting 2 codes since the Spartan upgrade - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by beaslyb, this thread has received 6 replies and been viewed 1662 times.
post #1 of 7 (permalink) Old 04-16-2011, 01:55 PM Thread Starter
I've been running the new 250 tune for a week and twice I've gotten the P0401 and a p1000 code, has the new tunes caused something? I know I used to hear the egr cycle at idle but I haven't noticed it with the new tune, what's going on?
08 Job 3 250 4 door, 6 inch lift, AFE straight piped, AFE drop in filter and Spartan tuned. 91 Procharged mustang
beaslyb is offline
post #2 of 7 (permalink) Old 04-17-2011, 01:40 AM
Spartan Diesel Tech
08stroker250's Avatar
Run the 175 tune for a day and see if your EGR frees itself up. P1000 is completely normal.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #3 of 7 (permalink) Old 04-17-2011, 11:55 AM Thread Starter
Okay I'll try that, does the egr not cycle with the new tunes? Or will running the 175 make it operate normally to free it up?
beaslyb is offline
post #4 of 7 (permalink) Old 04-18-2011, 06:06 AM
Spartan Diesel Tech
Should cycle with all of the tunes up to the 250 tune. The 210, 210 TP, and 250 tunes only cycle it at idle. Running the 175 tune will allow it to cycle all of the time and should free it up.
post #5 of 7 (permalink) Old 04-19-2011, 12:46 AM Thread Starter
thanks, just what I wanted to know.
beaslyb is offline
post #6 of 7 (permalink) Old 04-19-2011, 03:55 PM
Greenshield's Avatar
Ahh, i thought the update made it cycle on the 275 too, unless you loaded the EGR off tune. That explains a lot.
08 Job 2 Lariat CC SB 3.73 6.4
4" custom (i.e. made from parts from here and there) DP back SS exhaust
S&B Oiled CAI
Spartan Tuned (275)
Powerstroke 67 DPF/DOC delete
Recon Smoked Cab Lights
Dual Headrest DVD/Monitors
Rhino Liner
Greenshield is offline
post #7 of 7 (permalink) Old 04-20-2011, 02:11 AM
Spartan Diesel Tech
There is known issue with the regular 250 tune. Numerous people have reported this code with it. I have informed Matt about it, so hopefully he will get it fixed soon. The best thing to do is run the 250 EGR delete tune if you would like to run the 250 and then tune down to the 175 once a week or so to allow the valve to cycle some.
spartan tuner is stock now flash upgrade skter97 2008-2010 6.4L Engine Tuner Forum 2 03-30-2010 01:29 AM
Spartan Tuned and cold weather Codes 2263,2563 Hollywood 2008-2010 6.4L Engine Tuner Forum 47 01-31-2010 12:50 AM
p0281 and p0307 codes with spartan 250 bigbucks8 2008-2010 6.4L Engine Tuner Forum 4 10-12-2009 05:23 AM
Spartan Diesel with upgrade on the new 6.7-liter PowerStroke CGiron 2011+ 6.7L Power Stroke Diesel 1 10-03-2009 12:34 PM
upgrade from h2e Orangepstroke 1994-2003 7.3L Power Stroke 9 03-03-2009 03:20 AM
