Transmission Re-learn Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Truckmaniac, this thread has received 1 replies and been viewed 1735 times.
post #1 of 2 (permalink) Old 05-26-2011, 03:03 PM Thread Starter
I run the Spartan 250 tune as my daily driver.
Since I don't Race my truck, I haven't ever done the re-learn procedure referenced here on the forum : Accelerate from a stop at 1/4 throttle, do the same at 1/2 throttle, then at full throttle, etc.
Is my transmission learning my unique driving habits, like it does with the stock tune or should I be doing the "tuned" re-learn process?
The only complaint that I've had is the transmission not knowing what to do when coasting down to approximately 20 mph then accelerating, and I'm not talking about "Getting on It", just normal acceleration. It usually chooses to "slam" into gear.
Truckmaniac is offline
post #2 of 2 (permalink) Old 05-27-2011, 12:33 AM
Yep mine slams hard at 20mph, I make sure I don't hit the throttle around that speed, if so it feels like the trans is coming out. I've done the relearn a few times, to be honesest I'm not sure if it did anything or not, it still shifted hard. The relearn process is by far the hardest my truck has been abused and I feel like I'm tearing it up in the process, I've not done it in the past 15 times I've switched tunes, to me it's too hard on the truck for what it might accomplish, but I seem conservitive to most that run the high hp tunes.
08 Job 3 250 4 door, 6 inch lift, AFE straight piped, AFE drop in filter and Spartan tuned. 91 Procharged mustang
beaslyb is offline
Transmission Question Fast_and_furious 5.9L Cummins 12 Valve (1994-1998.5) 16 04-16-2010 12:19 AM
Transmission question bubafats 5.9L Cummins (2003-2007.5) 1 10-17-2007 07:10 PM
transmission question tommy vestrat 1994-2003 7.3L Power Stroke 9 04-05-2007 03:21 AM
Transmission question Phoneguy982 2003-2007 6.0L Power Stroke 9 06-22-2006 04:04 PM
Transmission Question stsdakota1 General Ford Truck and Excursion 0 04-10-2006 07:25 AM
