Dpf delete cat delete air box - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by drafthoss40, this thread has received 6 replies and been viewed 1663 times.
post #1 of 7 (permalink) Old 09-02-2011, 02:38 PM Thread Starter
Question Dpf delete cat delete air box
I will be putting an s&b intake, mini maxx and exhaust or dpf/cat delete not sure yet
First off can I do tha air box and tuner first and in a few months do exhaust?
That is what I have $$$ for now.
Any relevant info would be great.
And what is advantage of a 5" exhaust over a 4 "?
Will leaving the dpf on cause problems?
Thanks
Rich
drafthoss40 is offline
post #2 of 7 (permalink) Old 09-02-2011, 03:37 PM
pyro2nite's Avatar
Thanks
Rich
You can do the exhaust last because the tuner has DPF on tunes. The air box can be put on at any time. The exhaust must be put on after the tuner if you eliminate the DOC/DPF.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #3 of 7 (permalink) Old 09-02-2011, 08:39 PM
Spartan Diesel Tech
08stroker250's Avatar
No advantage of 5" over 4" because the biggest downpipe you can get on the truck is 4". Stock is only 3" in diameter on the inside. 5" does sound better though.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #4 of 7 (permalink) Old 09-03-2011, 02:17 AM Thread Starter
Thanks I just bought the Mini Maxx and the S & B intake should be here on Wed.
post #5 of 7 (permalink) Old 09-10-2011, 04:37 PM Thread Starter
When should I defuel 6.4 w/mini maxx
I put a mini maxx on along with an S & B intake. I hope to put a 5" exhaust from the down pipe back in the next 3 weeks or so. My first drive egt was around 1000 1250. I then put it back mild. Could someone let me know what top temp I should stay under.
Thanks for your time
post #6 of 7 (permalink) Old 09-10-2011, 09:06 PM
fine69's Avatar
I have the same setup as you, except I bought a DPF delete. The Mini Max will De-Fuel at 1450* You're safe up to that point, you can go over for short periods,.
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #7 of 7 (permalink) Old 09-11-2011, 01:46 AM Thread Starter
Thanks
Thanks that helps hauled tonight felt like I could brake the tires loose at any time. I Will let you know how it goes after the exhaust.
Tags
dpf tuner exhaust 6.4 cat
DPF delete 2007CumminZ 6.7L Cummins (2007.5-2011) 2 03-22-2010 07:26 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
need a muffler delete pipe, and pushy pipe delete ~CrazyDiesel~ 2003-2007 6.0L Power Stroke 13 03-31-2006 11:56 PM
