Spartan tuner question - 08 F250 - job 1 truck - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Biggredd, this thread has received 8 replies and been viewed 4456 times.
post #1 of 9 (permalink) Old 11-07-2011, 09:08 PM Thread Starter
So I just got an 08 F250 crew cab, long bed with 6" lift and 35" procomp extreme all terrain tires. The truck is way more than I'll ever need for sure. I do enjoy performance and the mpg increases of the tuners. I'm looking into getting the spartan tuner with dpf delete and have a couple of questions.
Other than the lift the truck is stock. It is a job 1 truck, 102,000 miles so just out of warranty. Has 3.73 gearing. I plan to do the 275 tune. The most I'll be towing will be a 9.5 pop up camper that weights maybe 1300 loaded (its pretty light) and a boat that I don't have yet but will still be reasonable.
My questions are:
Is this correct? I'll get a module to control the tune, I'll put a new CAI, and then then the dpf delete? I see a lot of kits adding 4 and 5" exhausts. Is it reasonable to run this tune and not add an entire new exhaust or is it beneficial? Do I get ride of the cat as well or is that part of the dpf?
The guy I bought the truck from has immaculate service done at a dealer. Is there anything I need to do when I put the mod on? Like change the transmission oil or beef anything else up?
Not really sure I understand the EGR delete portion yet. Can someone explain that to me a little better? Is that something I have to unplug and the tuner will compensate? Or does the tuner adjust automatically the EGR?
I plan to get it shortly after I get my license plates so not too much longer. Come on Christmas to me. lol
Biggredd is offline
post #2 of 9 (permalink) Old 11-07-2011, 10:49 PM
If you purchase our tuner, you have the option to purchase either the DPF/CAT delete pipe (only) or the full exhaust option. If you plan to run the 275 tune, either of these choices are acceptable. There is a bolted flange between the DPF and the CAT, but you want to remove both. Exceeding normal Ford servicing is not necessary. The 275 tune itself actually turns off the EGR so that it stays closed, therefore no other changes are needed.
SPARTANDIESEL2 is offline
post #3 of 9 (permalink) Old 11-09-2011, 09:12 AM
TDG Mafia Member #25
adrianspeeder's Avatar
I didn't see a need to upgrade the size of my exhaust, just get rid of the cat and DPF.
https://www.thedieselgarage.com/forum...d.php?t=110516
Adrianspeeder
adrianspeeder is offline
post #4 of 9 (permalink) Old 11-10-2011, 11:38 AM
pubs34's Avatar
I also have a job 1 , tuned the truck back in febuary, went with a spartan, love it. went with the down pipe back exhaust, changed the airbox over to AFE and had the charge pipe rebuilt. Think my truck loves me for letting it breath and cool down. Mostly I wanted to get rid of the regen, that just can't be good for the long term.You said something about towing and would use the 275, Spartan has a 210 tow mode, I use this, it has safe guards and protects the tranny, and has more power than you will need. I use the regular 210 as my daily driver, drop it to the 175 every now and then , 175 cleans out the EGR , 210 and up only cycle the EGR at idel. I did find a problem with the tuner, at about 125 MPH the sun roof starts to make noise
Spartan Tuned
AFE air box
4" stainless exhaust
2 1/2" lift
Tinted windows
Those nice heated leather seats
Sunroof
custom built charge pipe
pubs34 is offline
post #5 of 9 (permalink) Old 11-10-2011, 03:02 PM Thread Starter
Think my speedo tops at 100. Lol. I posted another post and never for a response so maybe it can be answered here. I know a guy selling a sct live wire 9621,.an afe cold air and a dpf for 750. Is that a good enough deal to skip the spartan ?
Biggredd is offline
post #6 of 9 (permalink) Old 12-01-2011, 01:38 AM
Spartan Diesel Tech
08stroker250's Avatar
Originally Posted by justsayno View Post
I have a 2008 F250 as well and the best advise I have is stay away from Spartan. I to have a job 1 truck and if you dont have problems now with the spartan you will for sure.There tunes are junk on stock trucks, stay away..
Why don't you elaborate rather than bash? Your picking through any thread that has to do with Spartan and you are attempting to tarnish the Spartan name. We have a LOT of VERY satisfied customers that have anywhere from 20,000 to 150,000 miles on their trucks.
Email - [email protected]
2008 Ford F-250 CC/SB
08stroker250 is offline
post #7 of 9 (permalink) Old 12-01-2011, 01:55 AM
Spartan Diesel Tech
Hey I am not picking on anyone, I am telling the poster that I have pretty much the same truck and had nothing but issues with my tuner.I could lie and say it was a great experience but then I would not be telling the truth.
I am sure you have satisfied customers but you also have alot that are not happy. I am just saying it how it is. Sorry if this offends you but its true.
I'm not offended at all. Just pointing out the obvious.
post #8 of 9 (permalink) Old 12-01-2011, 02:26 AM
Gerry's Avatar
justsayno.... What was so bad with your tunes??? Please give more details of what happened with your truck and what the tunes did to it.
Gerry
'08 F-350 Lariat - 6.4L Auto, Crew Cab, DRW, long bed, 4x2 and 4.10 gears.
'08 F-350 Lariat Racing - 13.63 @ 101.7 mph with a 2.24 60
Modifications include DOC/DPF delete pipe, S&B Intake and Spartan tuning.
Gerry is offline
post #9 of 9 (permalink) Old 12-06-2011, 07:41 PM
Yes 750.00 for the tuner DPF and CAI is a good deal, tuner with OR package is almost 700.00 itself
jgrouppy is offline
Spartan Tuner ??? before buying snopro_69 2008-2010 6.4L Engine Tuner Forum 26 02-16-2011 05:46 AM
Spartan Tuner 08-09 6.4 Dual Tandem Ford Parts 7 03-14-2010 11:38 PM
Spartan Tuner DAL-TEX Ford Parts 0 10-20-2009 09:32 PM
Spartan Tuner ZR800GUY 2008-2010 6.4L Engine Tuner Forum 13 04-06-2009 01:24 PM
New 06 F250 Truck Question MLRey 2003-2007 6.0L Power Stroke 6 08-22-2007 10:54 PM
