power loss and throwing code p0500 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pdpablo6.4, this thread has received 0 replies and been viewed 1902 times.
post #1 of 1 (permalink) Old 06-26-2012, 06:52 PM Thread Starter
I live in Las Vegas Nevada and i have a 2008 6.4L i think its a job 1, F350, Lariat, 4 door, with a 6 inch lift and 37" Toyo MT's it has 110,000 miles on it. It has a H&S Minimaxx Tuner, S&B Intake, DPF-CAT Delete, EGR Delete & Replaced Up Pipes other than that pretty much stock nothing done to exhaust. Now to the issue when driving my truck will lose all power for about a 2 seconds and the check engine light will come on and all the gauges will zero out then everything will go back to normal and the check engine light will go off. If i check the diagnostics on the H&S Minimaxx it will say 1 DTC Found P0500 Vehicle Speed Sensor A. Also any ideas on keeping coolant temps down when pulling 5th wheel 18k trailer temp will get up around 228 - 230 when pulling grades and i have to back out of it. Thanks Paul i have read alot of good info on here and answered lots of questions i had but this is my first post.
pdpablo6.4 is offline
Help - loss of power & code 78 & others... Jason748 6.5L Diesel Engine 11 06-30-2009 04:13 AM
edge ez throwing code andrew1346 5.9L Cummins (1998.5-2002) 1 02-15-2009 02:46 PM
Banks throwing code *2GLAMIS* 2003-2007 6.0L Power Stroke 2 01-01-2008 03:52 AM
Truck throwing codes P0500, P1693, P0463 bad_cummins 5.9L Cummins (1998.5-2002) 6 05-16-2007 11:55 PM
Welded EGR throwing a code Rockaholic 2003-2007 6.0L Power Stroke 8 03-24-2007 03:31 AM
