Gauges - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GUTTS, this thread has received 24 replies and been viewed 4125 times.
post #1 of 25 (permalink) Old 07-08-2012, 03:08 AM Thread Starter
GUTTS's Avatar
Gauges
Anyone have pics of adding guages to their truck? Was mad about the alt. going and want to add volt gauge,exhaust temp, trans temp, and maybe boost
GUTTS is offline
post #2 of 25 (permalink) Old 07-08-2012, 03:42 AM
ADMIN/MAFIA
neeltburn's Avatar
If you want I can give you pics of Autometer C2s and an Isspro EV-2 sorry they are not in a Ford.
I would for sure put in Boost, Trans and Pyrometer. Amperage if you have a lot draw is a good idea as is fuel pressure. However with a Ford you are luck and can get a 4 gauge pillar. You still stock? if not I would expect the dash Daq or HS to read everything, however I would still prefer a old school gauge.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 25 (permalink) Old 07-08-2012, 07:18 PM Thread Starter
GUTTS's Avatar
That's cool , I'm stock for now I was thinking a gauge pod above rear view mirror or other
GUTTS is offline
post #4 of 25 (permalink) Old 07-09-2012, 02:58 AM
ADMIN/MAFIA
neeltburn's Avatar
Isspro EV 2 on the right, Air Lift Air Bag gauge on the left.
Autometer C2 day view
Lights on
Really Dark with Lights on.
These are in my truck so your pillar would be different but you can see the gauges.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
GUTTS (07-10-2012)
post #5 of 25 (permalink) Old 07-10-2012, 12:56 AM Thread Starter
GUTTS's Avatar
Very very cool thanks. I guess they only make the gauge pod above the rear view mirror for the chevy but I really like it
GUTTS is offline
post #6 of 25 (permalink) Old 07-10-2012, 12:34 PM
ADMIN/MAFIA
neeltburn's Avatar
I have seen them for the Fords. So you should still be able to get one. I personally like 4 gauge pillar.
Sent from my IPhone 4s An AT&T not so 4G phone via Tapatalk.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 25 (permalink) Old 07-11-2012, 12:35 AM Thread Starter
GUTTS's Avatar
I like the four gauge pillar too but want to be different and a little confused
GUTTS is offline
post #8 of 25 (permalink) Old 07-11-2012, 02:51 AM
ADMIN/MAFIA
neeltburn's Avatar
Just searched one of our vendors sites and it looks like there 99-07 have one part number and 08-10s have another. I do not know if the dash is that much different that it would not fit up. Oddly enough I do not see the overhead/mirror pod for the 6.4L either. Maybe call Autometer and Isspro and see what they say.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
GUTTS (07-11-2012)
post #9 of 25 (permalink) Old 07-16-2012, 01:38 AM
TDG Mafia Member #25
adrianspeeder's Avatar
Heh heh, Voltmeter stock on my ride...
You'd give up the handle for a pillar pod?
I just run the dashdaq and roll.
Adrianspeeder
adrianspeeder is offline
post #10 of 25 (permalink) Old 07-16-2012, 02:56 AM Thread Starter
GUTTS's Avatar
That's because u have a manual trans I have trans temp gauge in its place
GUTTS is offline
Gauges stmline 2003-2007 6.0L Power Stroke 11 12-20-2009 02:36 PM
Gauges StrokeThis Supporting Vendors Forum 2 04-08-2008 07:26 PM
need gauges 02f350sd Supporting Vendors Forum 2 04-08-2008 02:18 PM
Gauges Big Gray dodge 5.9L Cummins 12 Valve (1994-1998.5) 5 09-17-2007 01:23 AM
Full Sweep Electric Gauges or Mechanical Gauges stack 5.9L Cummins (2003-2007.5) 0 05-21-2006 05:56 PM
