H & S tuner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GUTTS, this thread has received 28 replies and been viewed 8067 times.
post #1 of 29 (permalink) Old 10-04-2012, 02:54 AM Thread Starter
GUTTS's Avatar
H & S tuner
Tuner is on the way. Is their anything that I need to know and I got the dash pod but want to paint to match the silver trim near the air vent anyone paint the plastic trim to match the trim in the truck with any luck? Thanks guys
GUTTS is offline
post #2 of 29 (permalink) Old 10-04-2012, 04:32 PM
08smoker08's Avatar
Hope you bought head studs with it. I just found out my head gaskets are blown. Make sure to set your defuel levels accordingly. Pretty easy to install and setup. Sweet tuner but make sure the truck is ready for it. Hate to see you have issues.
2008 Job 1 F-250 PSD
H&S Black Maxx
S&B intake
5" Flow Pro from DP Back
Michelin LTX-AT2
Tow Pkg
Snow Plow Pkg
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(TheDieselGarage.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
08smoker08 is offline
post #3 of 29 (permalink) Old 10-05-2012, 12:24 AM Thread Starter
GUTTS's Avatar
What do u set the defuel at and what power level have u been running it on, my truck has 70,000 miles on it and don't need any issues thanks
GUTTS is offline
post #4 of 29 (permalink) Old 10-05-2012, 01:13 AM Thread Starter
GUTTS's Avatar
Now u got me worried maybe I should run the truck with 0hp gain but dpf off
GUTTS is offline
post #5 of 29 (permalink) Old 10-05-2012, 02:26 AM
08smoker08's Avatar
First from what I remember talking to u. U are out of warranty correct. If so either way I would get your head gaskets checked to ensure u have no issues before putting the stuff on ur truck. My dealer charged $85 to check it. Definately worth knowing. If its not blown and u plan on running any power increases. I would definately run head studs. Also delete the egr as well. This is the way I understand these trucks. This is entirely my opinion. If u tune u need to do it right the first time and don't piece meal it like I did. Delete ur egr add head studs. Add a wastegate and blow off valve or just tune it and never up the power. Adding power to the stock truck will work for a while but could be costly later. I'm getting ready to finally do it the right way now that my gaskets are blown.
As for defuel levels.
Cold coolant 140
Hot coolant 220
Hot oil 210
Hot trans 180
Pyro 1450
Boost 47 psi
This is the way I set mine. I am by no means an expert. Just an electrical engineer that reads a lot of posts and talks to a few performance shops.
Have fun with the tuned truck. It's a whole new beast once tuned.
Hit me up if u have any questions. I'd be happy to answer them.
H&S Black Maxx
S&B intake
Michelin LTX-AT2
Tow Pkg
Snow Plow Pkg
The Following User Says Thank You to 08smoker08 For this addition to TDG:
GUTTS (10-06-2012)
post #6 of 29 (permalink) Old 10-05-2012, 05:18 AM
Let it all Ride
Eazydeezy's Avatar
My company truck has 185,000 miles on a full delete kit. No blown HG's. If you run around driving like an ahole all the time, youre at risk. Otherwise, drive it normal and it will be fine. The occasional romping wont hurt it.
Dominic
Eazydeezy is offline
The Following User Says Thank You to Eazydeezy For this addition to TDG:
GUTTS (10-06-2012)
post #7 of 29 (permalink) Old 10-05-2012, 05:20 AM
Let it all Ride
Eazydeezy's Avatar
I'm not saying 08stroker abuses his truck or anything, just saying that its out of the norm. Sorry Stroker if I came off like a jerk.
Dominic
post #8 of 29 (permalink) Old 10-05-2012, 10:10 PM
ADMIN/MAFIA
neeltburn's Avatar
How many miles you have tuned now? What since day 3 of ownership?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #9 of 29 (permalink) Old 10-05-2012, 11:33 PM
Let it all Ride
Eazydeezy's Avatar
Hey, it was day 4! . But I have 68k on the ticker. So that's 36k tuned running mostly the hot damn files. 0 problems.
Dominic
post #10 of 29 (permalink) Old 10-07-2012, 02:24 AM Thread Starter
GUTTS's Avatar
Got everything hooked up and the truck runs great. A had a nice scare today because Friday I got the pod holder painted and bolted in and wired in the tuner and loaded the tunes in for dpf present and worked great. Then my buddy helped me today to do the exhaust and after we bolted it in I started to down load the tunes for the dpf removed then the truck would not start so did it again and no start, then loaded dpf present and it would only start the first time then no second start, reloaded tune again no start. Called h&s closed called mike from extreme and told me to try loading oem stock tune and loaded it and then loaded dpf removed tune and everything works perfect but made me nerves. Thought I had a broken truck in the driveway for the weekend and screwed for work on Monday. All is good thanks mike.
GUTTS is offline
SCT 9625 OR tuner '08 0r '09 6.4l Delete tuner $450 shipped! 4613 Whats Been Sold 1 01-02-2010 12:08 AM
turning the SCT SF tuner into a custom tuner strokin6L 2003-2007 6.0 Tuner Forum 4 05-26-2009 03:05 PM
KEM Tuner Only SILVERSURFER08 Whats Been Sold 1 02-23-2009 06:38 PM
what tuner? 6L strokin 1994-2003 7.3L Chips & Tuners Forum 11 04-09-2007 02:02 PM
