HELP member down - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smurfz, this thread has received 11 replies and been viewed 4209 times.
post #1 of 12 (permalink) Old 12-20-2012, 09:50 AM Thread Starter
Super *********
smurfz's Avatar
HELP member down
I was working on my truck. 08 SuperDuty with the DPF delete and fully Spartan'd when I leaned over the hood with remote in packet and triggered the alarm.
Now both keys flash security and will not crank over the engine. Dashdaq dies fit recognize the computer. Just says no vehicle found then doing a scan. Also it seemed to erase all tunes as when I go to load tunes there are none on the card. I'm testing the sd in a computer this am and will update what is on card
Thx
BigTruck, Some Mods Blah Blah (Oh Yeah Spartan Tuned! with the 310, TCM and Fully Powestroked from the Turbo back!)
Canadian Club Member # 13
smurfz is offline
post #2 of 12 (permalink) Old 12-21-2012, 01:24 AM Thread Starter
Super *********
smurfz's Avatar
Guys I'm ****ed here. No one has suggestions ??
smurfz is offline
post #3 of 12 (permalink) Old 12-21-2012, 07:35 PM
digginsweatinswearin's Avatar
Call Bernhausen diesel in Langley bc, they are a couple hours behind so they will be around longer to help you out. They just spartanized my truck and they know their ****.
digginsweatinswearin is offline
post #4 of 12 (permalink) Old 12-23-2012, 01:07 AM
pyro2nite's Avatar
try this
Re-initialize Ford System 3 (or 4) Alarm System:
Disconnect the battery. Wait 2 minutes for the module to lose all traces of voltage.
Turn the ignition key to the RUN position.
Reconnect the battery.
Shut the key OFF and press LOCK on the drivers door switch.
It's called reinitializing the alarm.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #5 of 12 (permalink) Old 12-23-2012, 01:11 AM Thread Starter
Super *********
smurfz's Avatar
Thanks Pyro. Will try this as soon as I am home.
smurfz is offline
post #6 of 12 (permalink) Old 12-24-2012, 07:24 PM Thread Starter
Super *********
smurfz's Avatar
Originally Posted by pyro2nite View Post
try this
Executed those instructions, still no go........Tried mutiple combinations of those instructions in desperation to figure this out, and still nothing.
On the positive side, were narrowing it down.
smurfz is offline
post #7 of 12 (permalink) Old 01-02-2013, 06:54 PM Thread Starter
Super *********
smurfz's Avatar
ttt No other suggestions It's been weeks with this truck totally DOWN
smurfz is offline
post #8 of 12 (permalink) Old 01-05-2013, 02:15 PM
harry6.0's Avatar
I had something similar happen on my 6.0 years ago. When trying to reload SCT tune back to stock it corrupted the pcm and the SCT X3, everything was gone, pcm was completely blank, all files in SCT were gone, wouldn't crank or run at all. No amount of resetting anything helped. Contacted SCT, they had me get the serial number off my trucks pcm, and then sent a file to match and load into my SCT X3, which loaded into the trucks pcm and it ran again. I have a factory alarm on my 6.0, and I think they can cause a corruption event when custom tuning is involved.
1. I would try to contact Spartan first and see if they can help with a solution.
2. You may need to tow the truck to a Ford dealer and have them reflash the pcm.
3. Maybe contact these guys and see if they have a solution, http://www.allcomputerresources.com/index.htm
Let us know what the solution ends up being, as I'm always curious about these kind of events.
Harry
harry6.0 is offline
post #9 of 12 (permalink) Old 01-08-2013, 11:26 PM Thread Starter
Super *********
smurfz's Avatar
Update! Contacted Spartan. They suggested a fresh download of the tunes. I did this but the dash daq will not recognize any on board computer. Code reader also can't see the computer. I have tried every combination of lock doors, turn key on, disconnect battery, etc. no luck. Now I am 8 weeks with no start!!!!!! I am gong to tow to dealer for them to see what they can do! Wish me luck
smurfz is offline
The Following User Says Thank You to smurfz For this addition to TDG:
harry6.0 (01-09-2013)
post #10 of 12 (permalink) Old 01-20-2013, 01:26 PM
harry6.0's Avatar
Any update after towing to dealer?
Harry
harry6.0 is offline
new member Tex03cummins 5.9L Cummins 12 Valve (1994-1998.5) 5 03-18-2008 07:17 PM
New member Ackman70 Introductions 12 07-08-2007 12:25 AM
new obs member emerica454 Introductions 12 05-13-2007 09:55 PM
New Member...Hey Denverduramax Introductions 4 04-12-2007 01:31 PM
