DD and Spartan - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigbucks8, this thread has received 3 replies and been viewed 1513 times.
post #1 of 4 (permalink) Old 01-14-2009, 11:11 PM Thread Starter
f450. job 3. 4.30 axle
DD and Spartan
can someone please walk me threw on how to get the new "spartan" guages on my DD from the link on their site. i need the complete walk threw. my DD is new, just got it today with 2.0.0-1364. i have no tunes loaded, just want to get the Ford stuff and spartan guages stuff done first. in have windows xp in that matters
kurt
bigbucks8 is offline
post #2 of 4 (permalink) Old 01-14-2009, 11:23 PM
nordberg's Avatar
just download it. make a file on the sd card called "transfer" and put it in there. then on the DD go to the install icon and install it.
under settings select ford parameters and enter the number 3 then do a signal scan
08 f250 6.4
stock?
nordberg is offline
post #3 of 4 (permalink) Old 01-15-2009, 04:33 AM
Spartan, True Performance
mick1955's Avatar
Like nordberg said, first create a folder named transfer on the sd card. Then follow these directions:
Loading New Themes That You Made Or Downloaded
First copy it to the transfer folder on your sd card. Insert the sd card into the DashDaq, make sure it is turned off. From Gauges click Exit. Then click Setup. Now click Memory Card. Next click Install, & now Themes. Select the Theme you want to install.
Change Dashboard Themes (Different Gauges)
From gauges, click Exit. Then click Setup. Now click Display. Next click Theme, and select the theme you wish to display. Then click Ok. NOTE: Make sure you change the high warning colors on all gauges to a color that you will be able to see if you do reach the high warning limits that you have selected.
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
post #4 of 4 (permalink) Old 10-13-2009, 04:54 AM
Former chevy guy
Cheyenne19's Avatar
Can someone email this file to me?
09 F250
07 Classic CC alli 315's sold
03 LB7 ZF6 VA 150 5'' Straight piped 315/75/16 BFG MT's sold
79 F-250 400cid NP435 NP205 38.5 Boggers
If you can read this, thank a teacher. If you're reading this in English, thank a soldier.
Cheyenne19 is offline
Hey Spartan Dalpilot Supporting Vendors Forum 28 01-10-2009 06:26 PM
Spartan wolfeyes89 2008-2010 6.4L Engine Tuner Forum 65 01-05-2009 06:37 PM
Tell me about Spartan ChasJr 2008-2010 6.4L Engine Tuner Forum 57 12-30-2008 10:20 PM
SCT VS Spartan John_DeereGreen 2008-2010 6.4L Engine Tuner Forum 88 12-27-2008 05:46 PM
