turn truck on without sensors installed, wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jasonludwig99, this thread has received 9 replies and been viewed 6754 times.
post #1 of 10 (permalink) Old 02-28-2009, 08:39 PM Thread Starter
My buddy started my truck before the egt sensor was plugged into the delete kit. it started the first time now it won't start at all. I tried to run my sct livewire with the delete tunes but nothing seems to help. Im getting the code P242d which I think is for the the egt sensor. any ideas?
jasonludwig99 is offline
post #2 of 10 (permalink) Old 02-28-2009, 09:04 PM
I Eat Rice
forcefed6.4ford's Avatar
Try to get ahold of Eric with innovative or Matt with Spartan. Matt has a forced start procedure for guys that let thier buddies start thier truck when they are not supposed to.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #3 of 10 (permalink) Old 02-28-2009, 09:09 PM
Rudy@DPFDeleteKits's Avatar
Clear the codes and then try starting.
SCT LIVEWIRE 9625OR, SPARTAN TUNERS, AND DPF DELETE KITS IN STOCK! SAME DAY SHIPPING!
*WE WILL BEAT ANY ADVERTISED PRICE, GIVE US A CALL*
Toll-Free Sales # 1-866-757-6537 or (919) 636-1518
http://stores.shop.ebay.com/Rudys-Pe..._sopZ15QQ_scZ1
post #4 of 10 (permalink) Old 02-28-2009, 09:45 PM
powerstroker67's Avatar
If the problem is that the engine wont turn over at all when in the crank position. First disconnect the Battery's for about ten minutes, reinstall cables,clear codes and try to start truck. If that doesn't work, turn key to run position and you will have to get under the truck and jump the starter with a 12volt power source from the battery. This is not very difficult if you can get under the truck and find the small red trigger wire going to the starter. Call me if you need help. Sean 860-250-6082
SPARTAN SCT + H+S TUNERS IN STOCK,SAME DAY SHIPPING TIL 5PM
NEW 6.4 COOLER ONLY DELETES, 6.7 COOLER DELETES BUILD INHOUSE!!!
ONE PIECE, BEST FITTING, AND USA MADE CAT/DPF 3.5,4 AND 5 CUSTOM APPLICATIONS AVAILABLE
[email protected]
www.streetdieselperformance.com
(860)250-6082 Sean tech questions
www.dpfdeletekits.com
(919)636-1518 Aaron sales
2011 F350 Lariat, CC,SB,SRW H+S MINI,CAT/DPF W/ full 5" Magna, 8" Procomp, American Force 22",37" Dunlop Maxx Tractions
2008 F450 Lariat,4X4,4.88's,Job1,Loaded,Spartan310,TCM,SCT w/ Eric's tunes,Elite studs+EGR delete,Updated Head gskts.,POWERSTROKER67 CAT/DPF pipe,AFE,Suncoast T/C,Spearco
powerstroker67 is offline
The Following User Says Thank You to powerstroker67 For this addition to TDG:
jasonludwig99 (02-28-2009)
post #5 of 10 (permalink) Old 02-28-2009, 10:08 PM Thread Starter
Is it possible that i blew a fuse for the starter while starting the truck without the egt sensor connected? im goin to try to start it with another battery now thanks guys
post #6 of 10 (permalink) Old 02-28-2009, 10:33 PM
No I don't think a fuse is blown. If you know the sensors are good and plugged in then I think you just need to bypass the starter safet'ys and make it turn over by jumping the starter solenoid. These truck's have a fail safe that prevent the truck from restarting if the exhaust has seen extremely high temps. If the truck was started with out the sensor plugged in then the computer see's a temp that was at max high. Your welcome to call me for detailed help.
[email protected]
jasonludwig99 (03-01-2009)
post #7 of 10 (permalink) Old 02-28-2009, 11:44 PM
This is called a "No Start Mode" - if you try to start without the EGR sensors in place, it will not crank.
You must jump it from the starter (from what I have read in the past)
clevalley is offline
post #8 of 10 (permalink) Old 03-01-2009, 02:20 AM Thread Starter
Im goin to try to start my truck first thing in the morning by jumping the starter. I have a feeling that will work thanks
post #9 of 10 (permalink) Old 03-01-2009, 03:59 AM
Spartan, True Performance
mick1955's Avatar
Correct. It must be jumped from the starter, then it should start like normal...
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
post #10 of 10 (permalink) Old 03-17-2009, 09:54 PM
dgrindst's Avatar
Ford special service message 20619: PCM shuts down on 1 hour timer when open or intermittent circuit faults are present or when egt sensors are disconnected. Disconnection batteries will not erase the codes or fix the problem. If the problem is not fixed the PCM will go into another 1 hour shutdown when key is cycled again.
2008 F450 4X4, 6.4 PS, Edge CTS, SCT 9625OR with RCD 450 V12 tune, S&B airbox, Flowpro 5" exhaust, down pipe, egr block, Banks intercooler, RCD charge air pipe, Titan 60 gal tank, Air Dog fuel system.
dgrindst is offline
HELP! truck wont start SSpeeDEMONSS 2003-2007 6.0L Power Stroke 29 04-01-2008 01:30 AM
Truck Wont Start shane 2003-2007 6.0L Power Stroke 3 03-31-2008 03:53 AM
truck wont turn!! 2008TT450 Duramax 2001-2004 (LB7) 9 12-29-2007 05:16 AM
truck wont start !!!!!!!! 7.3stroker 1994-2003 7.3L Power Stroke 1 09-03-2007 08:37 PM
Truck Wont Start weebz90 5.9L Cummins (1998.5-2002) 6 03-20-2007 05:25 PM
