P1335 code anyone have input - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08burnincoal, this thread has received 5 replies and been viewed 9472 times.
post #1 of 6 (permalink) Old 05-27-2009, 11:21 PM Thread Starter
P1335 Exhaust Gas Recirculation (EGR) Position Sensor Minimum/Maximum Stop Performance
Anyone run into this code before also noticed a little white smoke at idle, grey on accel.. Input would be great any fixes.. Thnks Guys
When I clear it it will stay gone for aprox. three start ups.. White smoke seems to clear up a little after running down the road..
Has anyone tryed removing the egr valve to clean it?>?????????????
08burnincoal is offline
post #2 of 6 (permalink) Old 05-27-2009, 11:57 PM
Probably some crud lodged in the EGR valve, as the code talks about the valve not being able to get closed down at the right spot.
kschmidt64 is offline
post #3 of 6 (permalink) Old 05-28-2009, 12:03 AM Thread Starter
Ya I thought of that as well but I can't get the danm thing out, think it take a special removal tool.. Need someone that has personnely experienced the problem..
post #4 of 6 (permalink) Old 05-28-2009, 04:16 AM
I Eat Rice
forcefed6.4ford's Avatar
When mine went. They had to remove the throttle body and EGR valve because they could seperate the 2. You might be in the same boat.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #5 of 6 (permalink) Old 05-29-2009, 03:19 AM Thread Starter
Did you get any codes at all?????? or running problems???
post #6 of 6 (permalink) Old 05-29-2009, 04:38 AM
I Eat Rice
Yeah it threw codes but I didnt have my DD with me to check them. Chugged and puffed grey smoke when it ran. no power and wouldn't build the rpms past 1500. Fixed in 3 days with waiting on parts.
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 03:36 PM
need some input blackcloudCTD95 The Parking Lot 31 10-12-2007 03:51 AM
P1335 DTC Help ejb17 2003-2007 6.0L Power Stroke 8 10-06-2007 02:05 PM
06-19-6 6.0l - Mil On - P0401, P0402, P0404, P1335, Lack Of Power, Or Surge. Egr Valv Squatch Ford Oasis requests 0 03-22-2007 04:00 AM
Need some input. Rebar 5.9L Cummins (2003-2007.5) 4 02-26-2007 12:11 AM
