Dealer Flashed my Truck without auth? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smurfz, this thread has received 21 replies and been viewed 2298 times.
post #1 of 22 (permalink) Old 06-30-2009, 05:40 PM Thread Starter
Super *********
smurfz's Avatar
They say that it wont affect the loading of the tune but I suspect it will? Can I drive it home and what do I do it it goes in to regen as I have the DPF Delete pipe on
(I drive home offroad)
BigTruck, Some Mods Blah Blah (Oh Yeah Spartan Tuned! with the 310, TCM and Fully Powestroked from the Turbo back!)
Canadian Club Member # 13
smurfz is offline
post #2 of 22 (permalink) Old 06-30-2009, 06:24 PM
Diesel Kid
Super08Duty's Avatar
You took it in tuned? I would reload a tune and just driver it home. Try using a different tune.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #3 of 22 (permalink) Old 06-30-2009, 06:27 PM Thread Starter
Super *********
smurfz's Avatar
It has been in tuned many times. They all know not to reflash it. New mechanic though he was doing the right thing. Guess he never stepped on the gas to pull the thing in to the shop! I think the strategy code has changed which will cause tune load errors. I guess I will have to wait and see. I just don't know what will happen if it goes into "regen" with no DPF on it
smurfz is offline
post #4 of 22 (permalink) Old 06-30-2009, 06:53 PM
I Eat Rice
forcefed6.4ford's Avatar
I would be a bit pissy myself. Depending on what strat you had in the truck compared to the new one. You might be fine or might not be able to load the tune at all. If the truck goes into regen you just smoke some and thats it.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #5 of 22 (permalink) Old 06-30-2009, 07:12 PM Thread Starter
Super *********
smurfz's Avatar
So driving in Regen with no DPF is OK?
smurfz is offline
post #6 of 22 (permalink) Old 06-30-2009, 07:38 PM
sledneck57's Avatar
No it will run like chit. Your focked just send your new info in and get new tunes.
08 F-350 CC SB 4X4
Zex Nitrous
Spartan Phalanx
AFE stg 2
Flo-Pro 5"
Lift\Rims\Tires
Canadian Club #0
Ridin Dirty Club #37
sledneck57 is offline
The Following User Says Thank You to sledneck57 For this addition to TDG:
smurfz (06-30-2009)
post #7 of 22 (permalink) Old 06-30-2009, 07:44 PM Thread Starter
Super *********
smurfz's Avatar
64 Cal here I come... Just as soon as I pull the Stratagy Codes
smurfz is offline
post #8 of 22 (permalink) Old 06-30-2009, 07:46 PM
I Eat Rice
when was the last time you were flashed? I had my truck reflashed it made no difference with loading tunes. Try to reload first. If it wont take then get ahold of 64cal
post #9 of 22 (permalink) Old 06-30-2009, 07:49 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Whenever I bring mine in,...I get a bunch of pieces of paper and write on them..
"DO NOT REFLASH MY DAMN TRUCK!!!!!"
and I tape them everywhere..
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #10 of 22 (permalink) Old 06-30-2009, 07:52 PM
sledneck57's Avatar
I seen a guy ty-rap his plug in to the obd port so they couldn't unplug it and put a sticky note saying don't reflash on it.
08 F-350 CC SB 4X4
Zex Nitrous
Spartan Phalanx
AFE stg 2
Flo-Pro 5"
Lift\Rims\Tires
Canadian Club #0
Getting a dealer to reflash my truck? MMor101 2003-2007 6.0L Power Stroke 13 12-19-2007 05:30 AM
took truck to dealer imported_fast_and_furious 2003-2007 6.0L Power Stroke 2 05-04-2007 08:29 PM
Anyone had your truck flashed at ford lately? Dieselwrencher 2003-2007 6.0L Power Stroke 9 10-06-2006 11:56 PM
Taking truck to dealer tomorrow YFZPILOT 5.9L Cummins (2003-2007.5) 0 03-24-2006 03:55 AM
Truck back from dealer lubeowner 2003-2007 6.0L Power Stroke 4 09-18-2005 09:33 PM
