Toasted torque converters :bang - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rene G, this thread has received 11 replies and been viewed 2260 times.
post #1 of 12 (permalink) Old 11-18-2009, 02:00 AM Thread Starter
Rene G's Avatar
I'm looking for those of us that are starting to have converter problems. I would like to see how many miles you have on and what tunes you run, also what are you seeing for tqslip locked and unlocked.
I have run mostly the 275 and can see 1200rpm slip unlocked and 50 locked with 25k miles.
Rene
09 F-350 FX4 lux package, everything but sunroof
Suncoast rebuilt trans. and converter
Line-X box liner and rocker panels
4-lightforce lights on KC light bar
OUO Traction 5"traction blocks
Icon adjustable track bar
Air bags and compressor
Icon 2.5" Leveling kit
Marathon sled deck
Flo-pro exhaust
S&B intake
Waiting for time to install
Dirty Diesel cold side I/C pipe
CANADIAN CLUB MEMBER #15
SINGLES CLUB MEMBER #227
spartan tuned courtesy of www.dirtydieselcustoms.com
Rene G is offline
post #2 of 12 (permalink) Old 11-18-2009, 02:44 AM
I will add mine here, i get 800-900 rpm unlocked and up to 50 locked 60,000 km tuned, hasnt been off 275 its been like this for the last 20,000 km i want to get more out of the tranny, to me while the tranny is out it might as well get rebuilt. it gets used hard and had some learning to do like when 4x4 hard to put it in tow/haul to keep the tranny cool bc of not doing that i had the tranny up to 230 once then the fan finally kicked on and was able to stop alittle after to cool down. im thinking around the 150,000 mark if $$$ allows.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 12 (permalink) Old 11-21-2009, 03:41 AM
Jesse@MBRP's Avatar
Send a message via AIM to Jesse@MBRP
I see about the same here with my RCD tunes. Suncoast convertor on the way after new years.
post #4 of 12 (permalink) Old 11-21-2009, 04:25 AM Thread Starter
Rene G's Avatar
I'm bitting the bullet and getting a suncoast rebuild trans and converter from Dirty Diesel.
Marathon sled deck
Flo-pro exhaust
S&B intake
Rene G is offline
post #5 of 12 (permalink) Old 11-21-2009, 03:24 PM
Super Moderator
John_G's Avatar
Don't buy-into the idea the Kevlar or other aftermarket clutch material is better, you NEED more discs.
Why do I say that? A lock-up TC is really no different (in lock-up) than a standard clutch, grip is a function of the coefficient of friction, force and area.
You can't increase area w/o more discs (double disc for example).
You can't increase TC pressure (lock up) because after a point (not far from factory) and generatae excessive heat and stress on the piston seals and they fail.
You can't really change coefficient of friction, except to keeep the ATF clean. Different clutch materials may have more friction, but that means they will wear out other components instead.
From what I have seen, the single biggest player in TC problems with regard to slipping is leaving the ATF in too long then changing it. As ATF ages (heat and time) the coefficient of friction changes to the positive, that is to say it has more grip with age and heat cycles. Now you change that out and put in new ATF with a lower fricition coefficient and the trans is shifting at the adaptive it had for the old "grippy" ATF so you get slip. Not enough to notice or set a DTC, but some. This slip in higher power vehicles can rapidly degrade the clutch packs, including the TCC.
The best thing to do is keep the ATF clean and reset the PCM/TCM every transmisison service by pulling the KAM fuse for 5 minutes.
I vote for LIBERTY!
John_G is offline
post #6 of 12 (permalink) Old 11-21-2009, 05:43 PM
Jesse@MBRP's Avatar
Good information man.
post #7 of 12 (permalink) Old 11-21-2009, 11:07 PM
FukeneH
dirty mech's Avatar
did you price out NAPC just woundering
dirty mech is offline
post #8 of 12 (permalink) Old 11-22-2009, 12:25 AM
powerstroker67's Avatar
This is very good information and I would like to add a bit more info. It is very true, adding friction material surface area is the best way to get a converter to stay locked up with more hp going thu it. Remember that these stock coverters are already "double" disc and have dual friction or clutch surfaces. The stock cover has an outer and inner clutch(one inside the other). The problem is that the friction is only as good as the steel it is being applied against. Many converter failures are caused by hot spots and distortion of the applied surface,main the front cover(part the studs stick out of). Once the steel surface is no longer flat you loose this friction needed to prevent slipping. Without have a very good understanding of what is gooding on inside that "magic hole", you don't always get what you think your getting. After having cut open and inspected many brand new converters for all the big companies, I can tell you many company's bend the truth on the internals of both converters and trannys. Take for example the stock Ford clutch portion of the 5R110 converter, put that inside a billet front cover and you have built a billet dual disc converter. It only offers a stronger applied surface, but the same amount of friction. Another "trick" is to glue friction material to both sides of a friction plate and then applied it against a steel plate with friction material on one side of it. You now have 3 friction surfaces and a "triple" disc converter.
As far as friction material, there are many different types. It's kinda like build a Southbend clutch. You can start out of "O" for organic, go to a "O FE" for organic on one side and more aggresive brake pad type material on the other, then we go to "FE" which is that more aggresive material on both sides. As you go from clutch to clutch, the ability to hold higher HP increases. As the limits of a single disc was found, Southbend went to a double disc setup to increase friction surface as mentioned above. We custom build a bunch of Dodge and Ford converters and friction material does make a difference. Most of the differences are in the way the clutch comes it or applies. We will bond a different friction material on a single disc vs. multi disc(using the same billet front cover and stator), just because of the difference in how aggresive the lockup will be. I don't have a scientific test of friction material strength as is applies to holding power, but it has to make some difference just like different brake pad material having better/worse stopping power on the same steel rotor. The warning here is be very careful how a company "sells" you there product. It's very hard to see anything thru the hole in the converter.
SPARTAN SCT + H+S TUNERS IN STOCK,SAME DAY SHIPPING TIL 5PM
NEW 6.4 COOLER ONLY DELETES, 6.7 COOLER DELETES BUILD INHOUSE!!!
ONE PIECE, BEST FITTING, AND USA MADE CAT/DPF 3.5,4 AND 5 CUSTOM APPLICATIONS AVAILABLE
[email protected]
www.streetdieselperformance.com
(860)250-6082 Sean tech questions
www.dpfdeletekits.com
(919)636-1518 Aaron sales
2011 F350 Lariat, CC,SB,SRW H+S MINI,CAT/DPF W/ full 5" Magna, 8" Procomp, American Force 22",37" Dunlop Maxx Tractions
2008 F450 Lariat,4X4,4.88's,Job1,Loaded,Spartan310,TCM,SCT w/ Eric's tunes,Elite studs+EGR delete,Updated Head gskts.,POWERSTROKER67 CAT/DPF pipe,AFE,Suncoast T/C,Spearco
powerstroker67 is offline
The Following User Says Thank You to powerstroker67 For this addition to TDG:
mmayo (11-22-2009)
post #9 of 12 (permalink) Old 11-23-2009, 03:57 AM Thread Starter
Rene G's Avatar
I called them and they said they didn't have anything for me
Marathon sled deck
Flo-pro exhaust
S&B intake
Rene G is offline
post #10 of 12 (permalink) Old 11-23-2009, 06:15 AM
So is there a best replacement or one that shines above others?
CC#16, the club not the whiskey!
zeddy is offline
Torque Converters mfd60 2003-2007 6.0L Power Stroke 8 07-02-2007 12:59 PM
Cheaper Priced Billet Torque Converters 95psdF250 The Parking Lot 7 05-26-2006 12:15 PM
Torque Converters: 101 Smokem 5.9L Cummins (1998.5-2002) 0 04-23-2006 03:42 PM
Bang Bang!!! 4S FED The Parking Lot 7 03-10-2006 03:53 PM
Torque converters BROKER 1994-2003 7.3L Power Stroke 6 05-24-2005 10:58 PM
