310 tune & miss shift (Mick1955) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hotrodstones, this thread has received 5 replies and been viewed 1464 times.
post #1 of 6 (permalink) Old 02-13-2010, 12:29 AM Thread Starter
hotrodstones's Avatar
I am currently running the tcm 310_V_1 yesterday getting on it, the trans mised 3>4 shift, patern 3>4<3>6th & coming to a stop never droped down to 1st, rolled out in second gear had to pull over & re start the engine. this has happend a few times in the past the trans not gearing down to 1st. been running the 310 just befor the release drove down & had Matt up date me also installed the updated TCM. I have had shifting problems under hard acceleration from the beginning with the 310 & TCM shift paterns
1>2>3>4<3>6 lockup & 6th is very soft some times not even felt, I know it engages 6th, when monitoring through IDS can monitor the shift paterns & line pressures. have not driven the truck much havent had time to update to stratagy flash. I am updating tomorrow, just loaded two separat SD cards with the new tunes & license, will try other tunes tomorrow!
Mick
Have you seen this with other trucks! I have about 3200 miles on the truck!
I also have always had when slowing down & rounding a courner then accelerating out of the turn it seems like I loose line pressure engine revs then bangs in to gear fluid level is good even added fluid over full no difernce!
Also this truck is never beat hard, just the odd hammer down
Thanks
Chris
2008 F-450 King Ranch Job 1 310/275/250/210 Spartain TCM, AFE cold air intake system, CAC pipe, Spearco Intercooler, Custom 5" sewer pipe into 4" dual tails, Mag-tech Deep sump trans oil pan, DDM Hid Kit.
2010 Montana Fith Wheel 36.5
Web Albumhttp://picasaweb.google.com/happycamper64
To do list
3stage water meth, SunCoast built trans & converter, Gear vendors over drive & Carbon one piece shaft, 22.5 Big Rig Wheels
hotrodstones is offline
post #2 of 6 (permalink) Old 02-13-2010, 12:33 AM
********* and Mafia #90
Bcarriveau's Avatar
Do you have the Revs per mile correctly Calculated for the spartan?
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 6 (permalink) Old 02-13-2010, 05:01 AM
Spartan, True Performance
mick1955's Avatar
Mick
Thanks
Chris
Is that the only version of the 310 that you have? These tunes have a relearn process that you must go through. You can't just go out and run the truck hard if your not driving it on a regular basis. If the truck is sitting or you are driving it easy then I would recommend going through the relearn process before getting on it hard. First, I would update to strategy flash. Then I would load the 310 strategy flash and then go through the relearn process. And remember, if you drive it easy for some time again you will need to go through the same thing....
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
post #4 of 6 (permalink) Old 02-16-2010, 08:12 PM
I like Pretty Girls!
Hollywood's Avatar
mine used to do that on the 275 but there was something wrong with the transmission..... then it let go and the tranny was toast
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
post #5 of 6 (permalink) Old 02-16-2010, 10:12 PM
I Eat Rice
forcefed6.4ford's Avatar
Wow Brent....Arent you a ray of sunshine
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #6 of 6 (permalink) Old 02-16-2010, 10:25 PM
Hollywood's Avatar
Ya I meant to add more but I posted it then got busy.... and I am having a ****ty day
I wanted to add that since mine was rebuilt ALL my issues were solved inc the 20mph one where is bangs into gear. Not sure what it was but it sounds like you have the same problems as I did
2008 F-350 Lariat
attn MICK1955 FX4F350 2008-2010 6.4L Engine Tuner Forum 2 11-17-2009 05:28 AM
Mick1955 is the MAN forcefed6.4ford 2008-2010 6.4L Engine Tuner Forum 21 02-28-2009 01:19 AM
New Spartan owner, need to thank Mick1955 and Beaux ODB 2008-2010 6.4L Engine Tuner Forum 16 01-03-2009 05:30 AM
Shift question w/tow tune jennamax 2003-2007 6.0 Tuner Forum 8 04-19-2007 06:04 PM
Looney Tune shift flare Shadow 2003-2007 6.0L Power Stroke 27 04-05-2007 08:26 PM
