Cracked and seperated manifold to turbo exhaust pipe? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ShauneSieben, this thread has received 10 replies and been viewed 6493 times.
post #1 of 11 (permalink) Old 02-25-2010, 12:58 PM Thread Starter
Well, i was gaining speed and pop... Then she sounded like a big block with no mufflers... Looked underneeth and found the passenger side exhaust pipe comming off the exhaust manifold had cracked and seperated.. Has anyone else seen this? From the exhaust manifold to the turbo pipe. I cracked right after the flange where it is bolted on to the exhaust manifold. Had no choice but to take her to the closest dealer ( i am at work 900 miles from my dealer. ) there was no point in trying to hide the tuner exhaust and intake, no means of changing back to stock where i am. Now it sounds like it won't be covered under warrenty.... What the %$#@ does that pipe have to do with my mods?? The way i see it it has to be a defective pipe and should be covered.. He may cover it once they get it off and see it was defective, but they have to remove the cab to change it... What a joke, who engineered these trucks?? If i have to pay it will be at least $2500.00 to change a 2 foot piece of pipe... I sure hope that this is not a sign of things to come!!! For the last month i have heard a small exhaust leak when cold and smelled exhaust, I figured it was a matter of time... Mechanic said that he seen the drivers side pipe crack before and he reccomends changing that one too when the cab is off.... At my cost of course.
Well, just had to vent....
Shaune
ShauneSieben is offline
post #2 of 11 (permalink) Old 02-25-2010, 03:50 PM Thread Starter
No one else has heard of this or had it happened??? Wow, my truck must be special... What is next? Glow plugs blowing out.... Hmmm I hope this is not the start of the 6.0 BS I delt with on my last 2 trucks.....
post #3 of 11 (permalink) Old 02-25-2010, 04:14 PM
Happen to my truck as well.
broth is offline
post #4 of 11 (permalink) Old 02-25-2010, 04:38 PM Thread Starter
Did they say what caused it? Just a deffective pipe?
post #5 of 11 (permalink) Old 02-25-2010, 07:18 PM
powerstroker67's Avatar
Up pipe failure on these 6.4's is fairly common at the flex joint between the manifold and the back of the turbo assemble. Usually sounds like a tea pot driving down the road.
SPARTAN SCT + H+S TUNERS IN STOCK,SAME DAY SHIPPING TIL 5PM
NEW 6.4 COOLER ONLY DELETES, 6.7 COOLER DELETES BUILD INHOUSE!!!
ONE PIECE, BEST FITTING, AND USA MADE CAT/DPF 3.5,4 AND 5 CUSTOM APPLICATIONS AVAILABLE
[email protected]
www.streetdieselperformance.com
(860)250-6082 Sean tech questions
www.dpfdeletekits.com
(919)636-1518 Aaron sales
2011 F350 Lariat, CC,SB,SRW H+S MINI,CAT/DPF W/ full 5" Magna, 8" Procomp, American Force 22",37" Dunlop Maxx Tractions
2008 F450 Lariat,4X4,4.88's,Job1,Loaded,Spartan310,TCM,SCT w/ Eric's tunes,Elite studs+EGR delete,Updated Head gskts.,POWERSTROKER67 CAT/DPF pipe,AFE,Suncoast T/C,Spearco
powerstroker67 is offline
post #6 of 11 (permalink) Old 02-25-2010, 07:24 PM
Usually the repair is done cab on and tranny out(much faster). Just as a suggestion.
[email protected]
post #7 of 11 (permalink) Old 02-25-2010, 07:37 PM Thread Starter
She broke off right after the flange that bolts onto the exaust manifold. Dealer said either the turbo has to come off or the cab.. Small town dealer, so I would rather have tem pull off the cab instead of mess with my turbo..? What do you think? Kind of screwed here, I am 1200k from home..
post #8 of 11 (permalink) Old 02-25-2010, 09:26 PM
They didn't say. It happened fairly early on when the trucks 1st came out so they didn't have much exposure yet to these types of problems.
broth is offline
post #9 of 11 (permalink) Old 02-25-2010, 11:38 PM
stroker
TylerDillard's Avatar
mine done it as well. it just had a split in it and i had a good welder in town weld it back up and all i dont was rempved the inner fender
TylerDillard is offline
post #10 of 11 (permalink) Old 02-26-2010, 12:55 AM
pyro2nite's Avatar
Cracked one when water splashed up on a very hot pipe. It was not a 6.4. Big bad 352 gasser.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
Cracked pipe?? is that it? TANK'S 250 2003-2007 6.0L Power Stroke 10 12-29-2007 07:41 PM
cracked injectors blown turbo monkeymandiesel 5.9L Cummins (2003-2007.5) 7 07-11-2007 05:30 PM
Cracked "Y" pipe TriGuy 2003-2007 6.0L Power Stroke 9 07-14-2006 08:59 PM
7.3 99-03 stock exhaust complete from down pipe to tail pipe Bella PSD Whats Been Sold 2 03-22-2006 12:21 AM
